Results 1 to 5 of 5
Thread: Rectifier tube question
    RDK
    RDK is offline
    Jan 2011
    27
    I'm working on my first amp. It's the amp build in the back of the guitar amp handbook.
    My question is about the rectifier tube in the schematic. One end of the tube (I believe pin 2 and 4) are the plates and are tied to xfmr. The other pins 6 and 8 (filaments) are also tied to another tap of xfmr.
    My question is :how is this possible. Doesnt the rectifier send DC voltage out? Wouldn't that collide with the ac voltage coming out of the xfmr? In the schematic pin 6 and 8 branch to xfmr and the circuit board.
    Any help in understanding this?
    Feb 2011
    41
    The yellow wires are typically 5 volt rectifier heater wires. The red ones are high voltage AC from the power transformer. The rectifier produces high voltage DC output (aka B+ or HT - High Tension) from the high voltage AC produced in the power transformer (PT).
    There are step up and step down windings in your PT.
    There is generally another low voltage output available, that is the 6.3 volt AC circuit for your heater filaments in your power tubes and preamp tubes. These wires are typically the green ones.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    You should note that the 5vAC for the heater is not connected to ground. It is floating. Think of those high tension power lines going across your town. The wires have thousands and thousandsd of volts on them. And yet small birds sit on them without harm. The reason is that the birds are not grounded, they offer no circuit for current to flow. Your 5v does not offer a circuit path for that DC to go anywhere through it. SO while it may be at +500v to ground, the thing is still free to flutter back and forth at 5VAC, just like my birds are free to ruffle their feathers even though they are sitting on 50,000 volts.
    RDK
    RDK is offline
    Jan 2011
    27
    Thank you so much! Both responses helped a lot!!!
    Feb 2011
    41
    Does this explain why (when no center tap ground is present) a DC voltage (17v from the power tube cathode, for ex.) can be introduced to the green heater wires thru (100ohm) resistors - That this DC voltage has no path to ground in that heater circuit?.
  1. Tube Rectifier Question
    By 12thfret in forum Theory & Design
    Last Post: 11-12-2010, 12:18 AM
  2. Replies: 2
    Last Post: 08-11-2010, 11:44 PM
  3. Rectifier tube question
    By thumbs in forum Tweed Builders
    Last Post: 10-25-2009, 03:19 AM
  4. Rectifier Tube question
    By MacLoud in forum 5 E 3
    Last Post: 11-15-2008, 09:06 PM
  5. Changing a rectifier tube question (Champ)...
    By mcinku in forum Mods & Tweeks
    Last Post: 11-17-2007, 05:33 AM
