Is that +6.9 volts or mv's?
If it is mv's, then I do not see an output device failure problem.
Is the lamp burning brightly (not so good) or did it glow at capacitor charge up & then go dim?(this is good)
Thought I would start a new thread here. I have this CS800 on the light bulb limiter , I am reading same voltages on both channels on the output boards ( right now -38 ,and + 38) Checking at the speaker outs I have -3.4 MV on one channel ,and + 6.9 on the other. What might I be looking for here ? Need more info ?
Thanks a heap, Tom
Sorry..that's mv. Glowed bright on charge then dim. Would the difference in the two be an issue if the other is - 3.4 mv ,and the other +6.9 mv . I'm just not sure how to tell which channel is working. I was told one side doesn't work. Rail voltage is low ,but the same on both channels ,and I have the limiter hooked up.
Thanks Jazz
OK..so I've found Q7 bad on one driver board...not sure about other components yet.
Positive Limit transistor: MPS6503.
Check the diodes around it & Q6.
If that is all that is wrong, get rid of the lamp limiter.
Your voltages will come up.
Voltages are low with the bulb in place? Well yes, the resistance of the bulb is in series with your transformer.
Once we know the amp is not going to blow fuses or burn up, get rid of the bulb. That is the purpose of the bulb, to let you power up without burning up the amp if it is still shorted. out. It is not intended that the amp will operate normally with the bulb limiter in place.
A few millivolts on the output is nothing, ignore it.
How do you tell which channel is working? By connecting a speaker and applying a signal. You were "told" one channel didn't work. WHo says that report is correct? We need to find out. I as a repair shop often see things brought in with "bad channel" problems only to find the unit works just fine and the problem was they had a dead output on their mixer.
Thanks Enzo. Can i just use a guitar , and connect it to one input at a time, and do the same with a speaker on the output? I did notice one thing with the triacs on the speaker outs. One of the resistors is supposed to be 1k ,color bands show that , but one on channel A reads 39 ohms ,and one on B reads 56 ohms. I have the circuit boards out.
Is there a chance that you turned the triac on when you where measuring.
Normally, a triac is off.
If in doubt, remove the triac & retest the 1K resistor.
You can now test the traic out of circuit too.
I removed both boards. The resistor was fine when I pulled one leg . I wouldn't have known if I turned on the triac. I did notice on the B channel that the nuts that hold the Triac on were loose. One was backed nearly all the way off. I'm going to pug it up ,and check it.
Thanks Jazz
As they are wired on the board, if the triacs do not seem to be shorted across the output, then they are probably just fine. That is all I look for, shorted or not.
You can use any signal you like, as long as it is enough to make the sound come out. A guitar is fine, though it ties up your hands. A Shure SM58 wouldn;t work well because the signal is so weak. I have a small stereo receiver on my bench to listen to a local FM station, and I have a cable plugged into the back of that, and I use the signal from that (REC OUT on the rear panel) as a general test signal. I'd rather listen to music than test tones. Got a CD player? I have a signal generator if I really need a clean signal for scoping or distortion tests. Somewhere around here we have a cheap little Yamaha keyboard - like you might find at K-Mart this time of year. It makes a reasonable test signal. I can play notes, or trigger its little demo tune. Sit my roll of solder on one of the keys and I get a continuous note. And when I am just looking to see if an amp channel even functions, a lot of time I do nothing more than touch the input with my finger, and the resulting hum or lack of it tells me the amp is functioning.
O/k, please bear in mind that the CS800 is a power amplifier.
THe input sensitivity is +3dBv (1.4Vrms) into 20K ohms for rated power.
Think Cd player or a mixer board.
A guitar can typically achieve 100mv's.
That is a wee bit short of 1.4V.
Personally I would test the amplifier into a dummy load, hooked up to a scope, with a proper signal amplitude.
ps: here is the link to the complete manual: http://www.peavey.com/media/pdf/manuals/80300991.pdf
Sorry.
I can't answer that one.
I don't work on chance
I am an amateur scientist
"Just the facts ma'am."
( Man I loved that show )
But, if the sound coming out of either channel is not distorted, then you are well on your way.
It is the fact that you are not even close to driving the amp to full power that would lead me to say the amp is not properly tested.
(again, that is just me)
Do you have any "gator clip" jumper wires?
The Cd plug is tip, ring, sleeve (from the top down, in that order)
The tip & ring are the positive output connections. Right & Left channels.
You only need one.
The sleeve is 0 volts (ground).
The 1/4 input cord is tip (positive) & sleeve (ground)
Have at it.
Got a guitar cord? Plug it into the CS800, and plug an RCA cord into the CD player. Spin the cover off the free end of the guitar cord. Now use a couple clip wires to connect the two cords together.
Or go to Radio SHack or some place and get a couple of those little adaptors you put on the end of an RCA cord to make 1/4" males. Use the regular cord the CD player uses.
You got volume controls? TUrn them down. COnnect the test signal to one channel and the speaker to the output, then turn the volume up slowly. If it sounds too loud for the speaker, stop turning it up.
Just because someone SAID a channel didn;t work doesn;t mean it is true. Lots of people THINK something is broken, when the problem really is elsewhere.
If I have a guitar around my neck, I might use it to test the basic function of an amp like this, but I would not expect it to drive the thing to anywhere near full power.
Thank you Enzo ,and Jazz . Sometimes I think my brain is just fried...and not from drugs...just from over thinking....I may actually have a Y cord somewhere...just need to find it. Thanks again..I'll give this another go.
OK...found my Y cable , hooked up the cd player ,and both channels play. Speaker isn't much but it works.
Thanks gentlemen.
