Results 1 to 7 of 7
Thread: Anybody Know About Ballast Tubes?
    Supporting Member Zer09's Avatar
    May 2010
    NJ
    78
    I'm restoring a Weston Model 981 tube tester which uses an Amperite 5h-12 ballast. My personal tester is also a Weston 981 so I've been able to use that ballast to get it working and calibrated. But I'm going to sell this one and need to find a ballast for it. I can't find them anywhere. The Amperite website says they still have some in stock and sell them but I can't get a response from them. I've found a 6-13 but don't know if it will work, and I've seen universal ballasts where you just cut the wires for the resistances you don't use. The trouble is I can't find any data on the 5h-12 so wouldn't even know if unversals would work.
    This ballast tube is used as a current regulator on tubes with 600ma serial filaments. Information on ballast tubes is pretty sparse but if what I've read is correct the first number is the current rating and the second is voltage drop. So I am thinking 500ma and 12 volts. So the 6-13 should work?
    Sep 2011
    119
    Antique Radio Forums • Index page
    Quote Originally Posted by Zer09 View Post
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    Antique radio supply should have NOS ballast tubes. Call the manager and make a special request. Tubes and more .com
    May 2010
    NJ
    78
    Quote Originally Posted by soundguruman View Post
    They were the first place I tried and I got no response.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,032
    CALL them, no emails.
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    Is the 5h12S just used in the filament supply? Normally used for a constant current sourcing, I also wonder if it is a critical part of the calibration. Most old tube testers use the mult-itapped filament transformer for "life" testing and cathode sensitivity testing.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  7. #7
    May 2010
    NJ
    78
    Yeah, it is solely for the 600ma filament tube types. As a hobbyist/guitar player I don't see myself using any in my amp builds so I'm putting my ballast in the unit I'm selling and if I come across one at some point at a local hamfest or something I'll pick it up for my own.
  1. Tubes
    By JC@ in forum Tubes (Valves)
    Last Post: 12-21-2009, 01:27 PM
  2. Tubes Help
    By thebullandmoths in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-06-2009, 05:13 PM
  3. 2 Tubes fixed bias/2 tubes cathode bias
    By lowell in forum Guitar Amps
    Last Post: 11-30-2007, 07:25 PM
  4. Replies: 10
    Last Post: 11-25-2007, 06:51 AM
  5. few different tubes....
    By jeffinwv in forum Flea Market
    Last Post: 09-07-2007, 07:17 PM
