Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By KilgoreCemetery
Thread: Request for Silvertone 1334 Schematic
    Dec 2008
    38
    Can't find a schematic anywhere for this one and information about this amp is scarce - anyone have one?
    I Picked up a Silvertone 1334 last weekend that was just about all original. Still had the original 6l6g and preamp tubes in her and the original utah speaker dating to 1956. Sound output was very low on it, so i recapped the power supply, put in a 3 prong power cord and changed the output tubes - she came alive nicely, but with a few issues I'd like to take care of. As i was working on it, the rca cable that runs from the top chassis to the bottom broke off at the solder joint and i want to make sure i put it back correctly. This looks like the one area of the amp that someone serviced because i can't imagine this would have been so poorly done from the factory.
    I know these were made by someone else for sears (Danelectro?) so perhaps someone knows of an equivalent amp under another brand name.
    Thank you!
    Tony
    Dec 2008
    Wernersville, PA
    12,144
    Silvertone 1344 Schematic
    As close as I can get is the 1344.
    I believe it uses 6V6 output tubes.
    There is a cable marked "Shielded Cable/ Upper Control Panel".
    It is for the Intensity Control pot.
    That may be the cable that you speak of.
    Attached Files Attached Files
    Dec 2008
    Wernersville, PA
    12,144
    Here is the original 1344 scan.
    Dec 2008
    38
    I figured it out and got a new cable installed, but still can't locate the exact schematic to the amp. The amp sounds very good! It really is a nice tweed style crunch machine that cleans up perfectly with the volume knob on my Tele (exactly what I love). It has a whooshing sound that comes and goes which I'm guessing is a bad tube(s). I think i'm going to try and either fix the tremolo next (doesn't work at all) or just measure out all the resistors in the circuit and blueprint it.
    Does anyone now if a simple push on/push off foot switch is what is required to turn on the trem? I have one of these lying around: Peavey :: Push On/Push Off Button Switch
    Dec 2011
    4
    Jaz,
    There are 3 versions of the 1344, with the readily available schematic being only the first and the 2nd/3rd versions being quite different. All I know is that the 2nd/3rd versions resemble more the other Danos from 1953-1955, so find one of those schematics if your amp is from approx October 1952 onwards. The 2nd/3rd versions used 6L6s and no field coil speaker.
    Sorry, that is the limit of my knowledge.
    Dec 2011
    4
    ..actually 4 versions if you count the 1304.
  7. #7
    Dec 2008
    38
    its actually a model 1334
    I think we're potentially getting our model numbers confused. my amp is a 1334. it is a 6l6 amp with dual chassis and a 12" oxford speaker dating to 1956. the tube complement is a 5y3,6sl7, 2x 12ax7's (one in the top chassis), a 6sn7gt and 2 6l6g's. the speaker is not a field coil and there is a trem and also a mic input.
    after rolling some tubes it quieted down a bit and i jammed with it. with a set of medium output humbuckers this amp has a surprising amount of gain and compression. more than my GA20T on the mic channel. is that normal? i hope so because it's fun!
    cleans up pretty well with the vol knob on the guitar too.
  8. #8
    Dec 2011
    4
    "I think we're potentially getting our model numbers confused".
    Very gentlemanly. I'll stop talking irrelevent garbage now!
  9. #9
    Dec 2008
    38
    Oh, i hope i didn't offend you - I certainly had no intent. My eyes have gotten tricked a few times by the 1344 schematic when hunting for the 1334 and i just though the same might have happened to you. Actually, I found your information very interesting. If there isn't a schematic for this model out there, maybe i could try and draw one. I've never done that before, but if it helps other people, I could try.
  10. #10
    Dec 2011
    4
    No, you didn't offend, I was just being stupid. Good luck with the search...
  11. #11
    Dec 2008
    38
    I worked a bit on this amp tonight trying to address some of the noise issues that i have not been able to solve by tube rolling. I changed all 4 resistors on the input tube to high quality metal films. I first changed the plate resistors and there was an improvement, then the cathode resistors for more of an improvement. This quieted the amp down substantially. I know using carbon comps vs. any other modern type is hotly debated, but this seems to have solved a big problem for me.
    Thoughts?
  12. #12
    Jun 2012
    1
    I have original owners manual for my 1334. Piece of paper with schematics on back. Willing to shoot pic of it for you.
  13. #13
    Jan 2018
    6
    Shot in the dark, but I am also in need of a schematic for a Silvertone 1334. guitarlix1, would you be able to upload a picture of the schematic please?
  14. #14
    Apr 2018
    1
    I have the original schematic that came with my 1956 1334
    Quote Originally Posted by KilgoreCemetery View Post
    I had one of these - I have the original schematic and would be happy to share with you - I have xerox copy for you - let me know where to send it
    John Strand -
  15. #15
    Jan 2018
    6
    Thanks, guitar1940! I finally found a copy on RadioMuseum.org and was able to fix the issue that I was having.
  16. #16
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,797
    Since the 1334 has not been posted here... Please post if you have it. Just remember that 1335 is nearly the same amp and only difference (I think) is the preamp. The 1334 has 3 inputs on the "instrument" just like channel 1 of the 1335, but the 2nd channel on the 1334 is one input with a simple single tone control. Other than that the 1335 schematic was very useful and accurate during a recent repair/resurrection I just did on one.
    http://music-electronics-forum.com/a...rtone_1335.zip
  17. #17
    Jan 2018
    6
    The PDF file is the schematic for the 1334 that I received from RadioMuseum. The jpeg is edited to reflect what I found while rebuilding, what I believe to be, a stock 1334. Hope this helps
    g1 likes this.
  1. Carlsbro Schematic Request
    By joslim in forum Schematic Requests
    Last Post: 05-29-2011, 09:23 PM
  2. Schematic request vox vt30
    By GEORADIO in forum Schematic Requests
    Last Post: 06-09-2010, 07:05 AM
  3. SWR 750X Schematic request
    By Rastus_1 in forum Schematic Requests
    Last Post: 04-10-2010, 02:40 AM
  4. Schematic Request?
    By JJGross in forum Music Electronics
    Last Post: 02-20-2009, 04:07 AM
  5. Schematic Request
    By bulldogguitars in forum Guitar Effects
    Last Post: 06-29-2007, 01:12 AM
Tags for this Thread
