See how hot the power tubes are running at idle.
Measure the DC resistance of the power tube's cathode biasing resistor with the amp off and all caps fully discharged....and then with the amp on, measure the DC voltage across that resistor.... divide the voltage by the DC resistance of the resistor to determine how much current is flowing through the tubes at idle.
It should be OK if the tubes re running under 13-15 watts each.
LinkBack URL
About LinkBacks
