Results 1 to 4 of 4
Thread: Laerge Diaphragm Mic Element... point which way?
    Dec 2011
    1
    I hope this is a simple question. I have a damaged KEL HM-2D which I have repaired. When reassembling, which direction should the element be facing? It has the wire screwed into one side, and the other side is of the element is simply bare. Is the screw side the front or back? This is my first time repairing a microphone. A genius friend of mine (**cough** um, actually me).., tried this mic out on a snare drum. It got hit a couple of times, dented the screen and broke the plastic bracket that mounts the element to the body... this caused the wire connected to the center of the element to also get disconnected. When I took it apart, the element was floating around inside the windscreen (not good at all)... so I didn't know which way it had been facing originally.
    Any help would be greatly appreciated. I don't want to assemble it the wrong way.
    g1
    g1 is offline
    Feb 2010
    9,153
    Well, from the picture in your link, that appears to be the wire side we are seeing through the screen. Or is that something else?
    Certified Dotard
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Yeah, it looks like that. Which puzzles me, as I'd expect it to be the other way round. The side with the wire connection and ring of holes round the perimeter ought to be the back.
    Once you get it back together, it will be obvious, since it's supposed to be a cardioid mic. Talk into it while listening through headphones. When you're talking to the "front" side of the diaphragm, the sound will be noticeably louder, fuller and clearer.
    Edit: I found this pic:
    rf7
    rf7 is offline
    Supporting Member rf7's Avatar
    Sep 2007
    582
    The screw side is the front of the capsule.
  1. Champ 600 Point-to Point Rewire! The first One?
    By Mandopicker in forum Mods & Tweaks
    Last Post: 11-05-2011, 08:43 PM
  2. point to point Blues Junior??
    By Groover in forum Mods & Tweaks
    Last Post: 09-07-2010, 06:21 PM
  3. Fender deluxe point to point clone
    By pappajoe in forum Debugging Your Build
    Last Post: 03-17-2010, 03:16 AM
  4. Point-to-point wiring or turret board?
    By chickenPlucker in forum Theory & Design
    Last Post: 04-19-2007, 08:16 PM
  5. Testing mic element
    By JC@ in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-15-2006, 11:13 AM
