Old 04-23-2007, 05:59 PM   #1
unresponsive speaker
I have a speaker that isnt responding, what might be the problem. I'm not sure of the history. The cone is bad, no dustcap so I assume the cone is bad. I'm just wondering what possible problems the speaker could have.
truetone is offline   Reply With Quote
Old 04-24-2007, 12:30 AM   #2
unresponsive in what way? Put a meter on it, is the coil open? if the coil reads at close to the rated impedance, I would suspect a dropped voice coil, or perhaps the coil is wedged in the gap due to being dropped, or a bent frame. We need more info.
Sweetfinger is offline   Reply With Quote
Old 04-24-2007, 01:40 AM   #3
to tell the truth, I'm getting it from a guy so I dont now yet. He said he hooked it up to two diffrent amps and it doesn't respond. He isnt any specialist with musical instruments and such so I dont have much info right now. The basket isnt all banged up it looks pretty clean. I was just wondering the possibilitys
speaker suggestion weeping6 Guitar Amps 29 01-04-2009 07:46 PM
Need a new speaker for my 5E3 I360up Tweed Builders 6 03-28-2008 04:35 AM
safely run 8 ohm speaker off 4 ohm amp? grandmasterflash213 Maintenance, Troubleshooting & Repair 1 04-17-2007 06:45 PM
Speaker recones ? Amp Kat Maintenance, Troubleshooting & Repair 7 02-21-2007 06:42 PM
Need some speaker help! Craig Music Electronics 2 08-23-2006 07:57 PM
