Results 1 to 5 of 5
Thread: Marshall TSL60 tube heater circuit
    Jan 2009
    20
    Hello all
    Been having a problem with the heater fuse inside on the circuit board blowing.
    It is a Marshall TSL60 about 12 years old.
    This has happened twice in the past 3 months.
    I posted in another area on here already.
    I was hoping someone could tell me where i can get a schematic of the heater circuit.
    Thank You
    Force3fan
    Oct 2007
    Buenos Aires, Argentina
    4,563
    Search for the TSL60 schematic , it should include the heater wiring.
    EDIT: there you have it:
    http://drtube.com/schematics/marshall/tl60-60-02.pdf
    Cluttered schematic, oh well.
    They feed 6.3V AC "Fil 1 / 2" to Power and PI tubes, then rectify with a Bridge and 2 10000 x 6.3V capacitors, getting "Fil A / B" for the others, but the input tube seems to be fed through a flying wire (dotted line) and has its own extra 10000 x 6.3V filter.
    IŽd pull the 6.3A fuse and measure AC current across the fuseholder terminals, without tubes and then inserting them one by one, until I find something unexpected.
    Any AC consumption without tubes is abnormal.
    Good luck.
    Please post results.
    Jan 2009
    20
    Thanks for your info.
    I did search and found a link to the schematic.
    Am waiting to get the switch then will start testing the circuit.
    It is very intermittent but a current test is the place to start.
    Thanks for the information.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,238
    I'd say the place to start would be to slip a different set of power tubes in there and see if it makes a difference.
    My surmise is that one of the power tubes is occasionally failing with a short to heater.
    Jan 2009
    20
    Thanks for the reply.
    I do have the orig. and that is the easiest thing to try.
    Again Thank You.
  1. Marshall TSL60 blowing heater circuit fuse
    By Force3fan in forum Music Electronics
    Last Post: 01-22-2012, 09:00 PM
  2. Marshall TSL60 - heater circuit blows
    By Force3fan in forum Guitar Amps
    Last Post: 01-15-2012, 02:13 PM
  3. Marshall JCM2000, Tube Heater Not Coming On
    By PepeSilvia in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-09-2011, 03:28 PM
  4. marshall tsl60 switching problems
    By cw695356 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-20-2010, 02:30 PM
  5. Marshall TSL60 - Excessive hum
    By Gank in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-20-2008, 01:08 AM
