Results 1 to 6 of 6
Thread: 6 Way 2 Pole Rotary Switch for 3 single coils.
    Member nicholaspaul's Avatar
    Aug 2010
    Bury St Edmunds, Suffolk, UK
    39
    I want to wire a rotary switch to 3 single coils, with the usual 5 plus neck+bridge. By mistake, I bought a 6 way/2 pole switch instead of a 4 pole. Can someone help me wire this, if it can be done? I'm not doing the PRS type of wiring with phase switching or anything so I thought it might be possible. Thanks
    Aug 2010
    39
    Will this work?
    Aug 2010
    39
    i tried this circuit out today and it works. There you have it, a working 6 position, 2 pole rotary switch diagram for three single coils. Hope that helps someone else out too.
    This diagram also includes a Fender Grease Bucket tone circuit, and a push-pull switch on the volume pot to switch the neck pickup out of phase. I use the neck+bridge position a lot so having this option on the neck just makes sense for me.
    Dec 2007
    Poland
    593
    Nick,
    Your Greasebucket tone circuit will not work because there should be a connection to the ground (it is missing on your drawing). Take a look here: Mod Garage: The Fender Greasebucket Tone Circuit - Premier Guitar
    Mark
    Aug 2010
    39
    Thanks Mark. I'll add it to the drawing. I had connected all the grounds in my test circuit but had only tested continuity not the function or sound of it. Thx!
    Aug 2010
    39
    Revised drawing, including ground for tone control.
  1. Source for good 4-way rotary switch
    By RoadToNever in forum Guitar Tech
    Last Post: 11-03-2010, 05:01 PM
  2. Which Rotary Switch?
    By retrorod in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-20-2010, 10:51 AM
  3. Danelectro rotary switch
    By avengers63 in forum Schematic Requests
    Last Post: 02-01-2010, 09:46 PM
  4. Best rotary switch for an attenuator?
    By Hardtailed in forum Theory & Design
    Last Post: 11-20-2009, 12:49 AM
  5. Replacing 2 DPDT switches with a single rotary switch?
    By yerblues in forum Music Electronics
    Last Post: 09-08-2008, 02:20 PM
