Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 04-25-2007, 12:10 AM   #1
PAF-style pickups
I'm tryin' ta find a pair of four-wire PAF-style pickups. There are so many different people offerin' PAF pickups, hot PAF pickups (though I find that somewhat confusing), and prices that vary wildly. They're goin' in an Epi LP that I want to wire up like my PRS (rotary selector, sweet switch). Opinions solicited and greatly appreciated.
Thanks,
dB
diode breath is offline   Reply With Quote
Old 04-26-2007, 05:46 PM   #2
are you looking for a classic PAF sound or something more modern with a hint of vintage?
in either case, there's plenty to choose from
Seymour Duncan: SH-1 '59 model, SH-55 Seth Lover model, SH-PG1 Pearly Gates, PATB-3 Blues Saraceno
http://www.seymourduncan.com/products/humbuckers.shtml
DiMarzio: DP103 PAF, DP194/195 PAF Classic, DP196/197 Virtual PAF, DP214 Virtual Hot PAF, DP190/191 Air Classic, DP213 PAF Joe (satriani), DP151 PAF Pro (I have one of these in the neck position on one of my guitars...sounds beautiful for blues, jazz, metal, rock, light chord work...very versatile and balanced sound)
http://www.dimarzio.com
there's also tons of smaller pickup manufacturers that make their own versions of PAFs as well as hotter versions.
Ultimately though, you gotta decide what kinda sound you want outta these pickups. Do some research, find out what these pickups sound like (most manufacturers usually have sound clips) and then figure out which ones would be right for you!
Good luck!
blakkwater is offline   Reply With Quote
Old 04-26-2007, 06:08 PM   #3
Thanks for your input, but what I'm looking for is a real-sounding PAF, not "modern with a hint of vintage", not hot, not overwound, but with four-wire connectability. I've played the DiMarzio, Seymours, and a couple others, but all were two-wire. I'm beginning to think I'll need to have a set wound, or disassemble a couple old 'buckers and wind 'em myself.
I talked to a custom pickup builder at the guitar show in Dallas last weekend, and he specifically mentioned a resistance between 7.5 and 8K. Didn't ask what sort of inductance value he was targeting, but I'm sure I can find that in the literature available on the interneck. Q factor? Didn't metion that, either.
Old 04-26-2007, 06:12 PM   #4
Pickup Maker
David Schwab's Avatar
Just get a 2 wire pickup you like and change the lead to 4 conductor.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 04-27-2007, 04:15 AM   #5
Just about any Seymour Duncan pickup can be ordered with four conductor wiring. The Duncan models which closest resemble what you're looking for would be the Seth Lover, '59, or Pearly Gates neck. There are also a bunch of guys on the pickup makers forum here who would be delighted to make you a killer set of 'buckers with four conductor wire.
Sweetfinger is offline   Reply With Quote
Old 05-15-2007, 12:19 AM   #6
madialex's Avatar
Quote:
Thanks Sweetfinger. I'm glad someone told him about the pickup makers section, sheesh it was starting to sound like a Seymour and dimarzio sales event around here.
If I was looking for an amp this forum would be the first place i'd check
madialex is offline   Reply With Quote
Old 05-25-2007, 11:35 AM   #7
Supporting Member
Steve A.'s Avatar
Quote:
Thanks,
dB
So what is used in the sweet switch? The last discussion I remember it was something like an analog delay chip. Is there a source for it?
I hear a lot of complaints from guitarists about the rotary switch- especially for a vintage sound you might want to stick with the standard 3 way toggle switch.
I don't know if you have any old PAF-style pickups lying around, but changing out the magnets can give them a new lease on life. I'm not sure in AMPGE is still in business, but I'd order a whole sh*tload of magnets from him: A2, A3, A4 and a few A5 (most of my pickups already have A5 in them so I don't have to order many of those). Humbuckers use 1 magnet; P-90's use 2.
In any case if the windings are close to original PAF specs (like 7 to 9k DC resistance), replacing the magnet with a different variety might give it a more vintage sound without having to spend a lot of money on boutique pickups.
Steve Ahola
P.S. I believe that the original PAF's were unpotted so if your pickups are potted you might not get a vintage PAF tone.
Steve A. is offline   Reply With Quote
Old 05-25-2007, 01:28 PM   #8
Supporting Member
Steve Conner's Avatar
PRS question... explains the sweet switch. At audio frequencies, I don't think the delay line does anything that a series R-C network or even a small capacitor wouldn't.
Steve Conner is online now   Reply With Quote
Old 05-26-2007, 12:55 AM   #9
Pickup Maker
Quote:
It's not an analog delay chip, like you would find in a pedal. It's more a bunch of coils and caps (LC network). They use these things in data circuits.
Try looking here: http://www.datadelay.com/. Look at the link of the left that says "Passive Delay Lines". I'm not sure if this is the exact same thing used by PRS, but I think it is the same type of device.
I'd go with a small value cap and a resistor myself.
That's correct. Gibson never wax potted any of their pickups until more recently. If you want vintage tone, don't pot the pickup.
__________________
Ceria Tone Trainwreck-style amps? Thorny Kit Amps 5 11-03-2008 04:53 AM
Need new source for Gibson-style braided wire Zhangliqun Pickup Makers 11 01-10-2007 08:17 PM
Modding a Fender style 'bright' input. The Captain Mods & Tweeks 30 12-06-2006 10:19 PM
Matchless Style Cut Control on SE amp greg Mods & Tweeks 3 10-03-2006 05:50 PM
What phase inverter style has the best output to linearity ratio? Macguyver Theory & Design 44 09-06-2006 02:13 AM
