Results 1 to 9 of 9
Thread: Fender Stage 100 DSP **** P R O B L E M ****
    May 2009
    17
    I need help!
    My amp is broken.
    The electronics I know something so I can to finish the job alone,
    but I need instructions about what can be a defect and how to fix it.
    Symptoms:
    - Very noise in the speaker
    - Mechanical damage to the parts you see in the photo
    Capacitater Steve Conner's Avatar
    Glasgow, Scotland
    6,786
    Looks like your output stage had a meltdown!
    Do you know what a transistor is, and how to test one?
    Dec 2008
    Wernersville, PA
    5,369
    Yeah, the circuit that you indicate is the "protect" circuit.
    If that is bad, there are most assuredly other issues.
    May 2009
    17
    I know a lot about electronics.
    I did never repaired amplifiers, But before I made ​​some other devices so that I know the basics.
    I suppose that the amplifier is turned on without speakers and that is the reason for this failure.????
    First I need to replace the two transistors what are damaged?
    So I should check the output transistors?
    Stage100_Stage100H_Stage160_schematic.pdf
    This is the original scheme of the amplifier
    Thanks
    Oct 2007
    Buenos Aires, Argentina
    4,492
    Those visibly burnt transistors are a symptom but not the original cause.
    Check Q10 to Q19 for shorts, all 0.47 ohm ballast resistors, and any diode you find there, just for starters.
    Google "lamp bulb limiter" and build one.
    Good luck.
    May 2009
    17
    Ok.
    One question.
    These parts, which you listed how to check in?
    Do I have to remove the parts and check in (I know to do it)
    or
    Is there a way to be checked without removing?
    P.S.
    I have a lot of measuring instruments and tools
  7. #7
    Dec 2008
    Wernersville, PA
    5,369
    It will not "hurt" the amplifier to operate it without a load (speaker).
    Keep in mind that the output section uses a grounded emitter.
    The current to drive the speaker comes "from" the power transformer windings.
    "This is not your dad's Oldsmobile"
  8. #8
    May 2009
    17
    Hahaha ...
    I know that.
    I bought this amp broken.
    The seller said that it is a input jack and that noise comes from broken input jack.
    I got a good price and it is the reason why I bought this amplifier
  9. #9
    Dec 2008
    Wernersville, PA
    5,369
    Quote Originally Posted by colmax View Post
    Ok.
    One question.
    or
    P.S.
    You can have all of the test equipment & measurement tools in the world but they will not help you repair this amplifier.
    What you need, in this case, is a familiarity with solid state output sections.
    If you do not have that, the repair will rely on a hit or miss approach.
    I would not recommend that to anyone.
    Sounds to me as if you really should take the equipment to a tech.
  1. fender stage 100 dsp 112 combo
    By klunk in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-15-2010, 06:32 AM
  2. Fender Stage 100 DSP
    By nwguy in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-08-2009, 05:47 AM
  3. Fender Stage 100 DSp Intermittent Output
    By hatcherd in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2009, 04:35 AM
  4. Fender stage 100 DSP Head need help
    By Jam in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-03-2008, 03:18 AM
  5. Need help with Fender Stage 100
    By depicks in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-02-2008, 12:45 AM
