Results 1 to 12 of 12
Thread: peavy vypyr 15
    Jan 2012
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    peavy vypyr 15
    Hi
    Is it possible to wire a distortion pedal into a peavey vypyr 15?
    When you read the peavey website it reads as though the vypyr amps will take a pedal, however not the 15 as we found out when it arrived.
    0 Not allowed! Not allowed!
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,032
    Thumbs Up/Down
    Received: 26/0
    Given: 33/0
    I'm not sure what you mean by "wire a distortion pedal into".?. How do you want to use the pedal, in line with a cable into the amps input, installed into the amp chassis, in the amplifiers effects loop? What problem did you have using a pedal with the amp?
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
    Jan 2012
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi Chuck
    The amp is my daughters so forgive me if I get the terminology wrong.
    She wants to be able to hit the foot pedal during songs to switch the distortion on ( not sure if in Usa its not called post gain?)
    The peavey Vypyr has not means of connecting a foot pedal unlike the Vypre 30 and bigger.
    May 2007
    pacific north west
    13,032
    Thumbs Up/Down
    Received: 26/0
    Given: 33/0
    Ah. Gotcha.
    I'll guess that the distortion is switchable on the amp. You would need to replace that switch with a remote switch. On a modern PCB amp "I" probably wouldn't do it. But there are guys here that have done it on other similar amps.
    If you can get the schematic for a Vypyr30 and compare it to a schem for the Vypyr15 you could see if it's an easy retrofit. Worth checking out.
    Dec 2008
    Wernersville, PA
    12,202
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    Actually, Peavey does have pedals available for the Vypyr Series of amplifiers (including the 15)
    Peavey :: Sanpera™ I
    Peavey :: Sanpera™ II
    http://www.peavey.com/assets/literat...03587000_4.pdf
    http://www.peavey.com/assets/literat...03587010_4.pdf
    They are a bit pricey.
    Jan 2012
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Jazz P Bass View Post
    Not for the 15
    There is no socket for 1
    And when you read the instructions it clearly states not available for vypyr 15
  7. #7
    Jan 2012
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Chuck H View Post
    Ah. Gotcha.
    The switch on the Vypyr 15 is a fancy multifunction job.
    It control a whole host of functions.
    It is actually a rotary switch with @ 10 different positions, and you switch to distortion by pressing the control knob.
    Would probably be possible to rig a small actuator to physically press the switch when needed.
  8. #8
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,046
    Thumbs Up/Down
    Received: 57/0
    Given: 59/2
    I *guess* than rather than physically pressing anything, or remotely dealing with the rotary switch in any way, the distortion (plus anything else) can be assigned to a certain preset and *that* preset switched on/off.
    On the left side of the panel I see 3 "bank" buttons and 4 "preset" ones.
    *Maybe*, if said are normal tact switches, you can connect one of them (2 wires) to a stamp sized add on board using an analog switch (1/4 of a 4066 , this shows how old I am ... maybe even a FET) , controlled by a honest-to-God jack and regular footswitch.
    Really I´m suggesting it only as an exercise of the mind, such surgery might cause more trouble than it´s worth, although once I did the same to remotely activate a VCR.
    A lot of "guess" and "maybe" and "if" involved here.
    And I guess the Peavey idea was to have a very competitive ($$$) 15, but have you wish the 30 soon.
  9. #9
    Dec 2008
    Wernersville, PA
    12,202
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    Quote Originally Posted by dropswell View Post
    Not for the 15
    "Sorry about that , chief"
    That truly s*cks.
  10. #10
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,856
    Thumbs Up/Down
    Received: 64/1
    Given: 0/0
    That is the most basic model, and doesn't have a lot of features the more expensive models do. They kept features to a minimum to keep price down.
    A shop like mine could take any control on the panel and make it remotable from a footswitch, but by the time you'd pay me to modify the amp in that fashion and create the footswitch for it, you might as well jusy invest in the higher up model that does what you want in the first place. Sorry.
    Having said all that, nothing stops you from setting the amp up for a relatively clean tone, and having an overdrive pedal out front of the amp, just as you might with a plain old amp. Stomp on the pedal for your soaring solos.
    Keep in mind that the Vypyr is basically a computer with a speaker. We can tap into the controls on the panel, but the "circuitry" for the distortions and tones inside it are all bits in the program. They are not places on a circuit board we can solder wires to.
  11. #11
    Jan 2012
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by J M Fahey View Post
    Done some investigation, and tapping into one of the programmable tactile preset buttons works a treat.
    Also means that the sound that is switched via foot pedal can be tweaked
    Cheers
  12. #12
    May 2007
    pacific north west
    13,032
    Thumbs Up/Down
    Received: 26/0
    Given: 33/0
    That's why I mentioned comparing schematics for the foot-switchable version of the Vypyr and your model. Since they're basically the same amp, the foot switch (and it's plug) were probably omitted in the less expensive model.
  1. Peavey VYPYR 15
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-25-2013, 01:49 AM
  2. Peavey Vypyr 15 problems
    By IbanezFan in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-13-2010, 02:42 AM
  3. Peavey Vypyr 15
    By sully57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-12-2010, 05:25 PM
  4. peavy vypyr 15 problem
    By jaime in forum Music Electronics
    Last Post: 10-30-2009, 02:21 AM
  5. New Peavey Vypyr 15 (problem?)
    Last Post: 08-05-2009, 06:06 AM
