Results 1 to 24 of 24
Thread: Trouble-shooting hum in a Fender 65 Twin Reverb
    Oct 2011
    54
    How do you find the source of undesired hum in a Fender 65 Twin Reverb? This amp seems to work fine except for a residual amount of buzz. The buzz is hardly noticed during loud use - but I would like to reduce (or eliminate) the hum.
    When V5 is removed, the hum remains. However, when (V6) is removed, the hum disappears (I assume this eliminates the output tubes and DC power supply from possible causes). For what it's worth, this model does not have the hum switch and I have tried to adjust the hum pot (per recommended procedure) with little success. Do guitar amps like the 65 Twin Reverb simply buzz no matter what you do? Is there anything I can do to reduce the hum?
    I would like to know is how much hum is acceptable when measured with a 'scope? In this case, scope measurements at the speaker jack (with 4 ohm resistive load) show spikes as high as 180mV peak to peak.
    Dec 2008
    Wernersville, PA
    12,104
    When monitoring output hum on a tube amp, I start to worry if it is over 9 mvs.
    4mvs is really good.
    But you are talking buzz.
    Those 180 mv spikes are definitely cause for concern.
    Do any front panel controls reduce or aggravate the buzz.
    If so, then the problem would be before that control.
    Check the interstage coupling caps for any leaking Vdc.
    g1
    g1 is offline
    Feb 2010
    9,763
    65_Twin_Reverb_schematic.pdf
    V5 is the tremolo tube, so removing it doesn't tell much. Removing V1 will take the normal channel out of the circuit. Removing V4 will take the vibrato channel out of the circuit.
    Certified Dotard
    Sep 2010
    123
    Is your amp an original made in 1965 Twin Reverb or is it the current production Reissue "65 Twin Reverb"?
    If pulling V6 quiets the hum then it is a good bet that the problem is in the preamp or phase inverter. Sub out each preamp tube one at a time with a known good tube to help narrow it down.
    Lifetime Member
    4,209
    Question #1 on hum/buzz issues is to ask whether it's a hum (i.e. all bass) or a buzz (spikes at the hum/buzz frequency.) Hum is from AC power line leakage or coupling, buzz is from some high frequency or switching process that recurrs at line frequency.
    Question #2 on hum/buzz issues is to ask is the noise 60Hz and therefore powerline frequency, or 120Hz, in which case it's coming from the rectification system in some way.
    The cures are quite different.
    Oct 2011
    54
    This is a 65 Twin Reverb reissue (about 10 years old). I just discovered the output tubes were biased way to hot! I believe a 6L6 maximum plate current should be 30 Watts. However, they were set to 38 Watts! Although a subjective value, I like to use the 70% rule - so I will adjust the plate current to 21 Watts. The output tubes seem to have "thrown-in-the-towel" with a measured output (at clipping) of 9 Watts! I will install a new set of output tubes to see how it performs. With any luck, the buzzing will "go away". I will also try all the other suggestions provided in this thread. This is a great place to "bounce" ideas off others.
  7. #7
    Lifetime Member km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    1,872
    You did not say whether gain or tone controls influence the noise amplitude, nor the frequency of the noise.
    The "watt" measurements do not make sense, where and how are you measuring watts, is it cathode current, plate dissipation or milliamps?
    Does the amp show even clipping at 9 watts(?). I doubt the power tubes are involved in this. What does the waveform look like on the scope?
    Have you for sure isolated the source to the power amp section with no control having any effect on the noise?
  8. #8
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,049
    Please define "watts" and how did you arrive to the numbers posted.
    Thanks.
  9. #9
    Oct 2011
    54
    I don’t understand why you want me to define “watts”, but here it is one definition: A unit of power, equivalent to one joule per second and equal to the power in a circuit in which a current of one ampere flows across a potential difference of one volt.
    I’m not sure what “numbers” to which you are referring; but if you review the specs for a 6L6, the datasheet will disclose the maximum plate dissipation is 30 Watts. As I mentioned, I like to run 30% below this maximum value (the popular 70% rule).
    If you are referring to how I determined 9 watts output, I measured output voltage at clipping was 6 Vac. I squared 6 Vac then divided by 4 ohms (load) which equals 9 Watts).
    If you are referring to how I determined 38 watts output per tube, I multiplied the measured plate voltage by cathode current. (407 Vdc multiplied by .094 amps equals 38 Watts). Keep in mind the screen accounts for a small portion of that power. In the case of this amplifier, the bias setting that produces 94 mA at 407 Vdc is more than triple the tube’s maximum value.
    With new tubes installed and biased to 21 watts on each output tube, the amplifier works great. However, the darn buzz is still faintly there.
    Now that I have answered your questions, I hope you can provide guidance on how to find the source of undesired hum in a 10 year old Fender 65 Twin Reverb.
  10. #10
    Oct 2011
    54
    I think I may have goofed-up. I thought providing values in Watts would be helpful instead of just mA. It seems to me that providing watts provides the complete "picture" instead of just half. Anyway, all the tone/volume controls have no effect on the undesired "buzz" that is occurring at 60 Hz. Viewing the "buzz" on a 'scope, you can see the spikes, although they are fairly faint - requiring the brightness of the 'scope to be turned-up. Sorry for any confusion I have created.
  11. #11
    Jun 2006
    California, USA
    3,446
    Check the integrity of the hum balance pot and make sure it is properly adjusted. You can also measure each side of the heater voltage with respect to chassis ground and verify that each side is approximatly equal at ~3.15Vac.
  12. #12
    Dec 2007
    Poland
    1,535
    Quote Originally Posted by AMPREPAIR View Post
    Yes, it was helpful but you confused other people by calling it "plate current" and specifying a value with Watts unit. Clearly current is not measured in Watts. You ment "plate dissipation", which is plate voltage (Volts) multiplied by cathode current (Amperes).
    Are you sure that the valves that you used are matched pair? Have you measured the cathode currents?
    It looks like the problem is related to the power amp or to the power supply but I would check the new valves first.
    Mark
  13. #13
    Lifetime Member
    4,209
    IF the buzz is happening at 60Hz, that limits the causes quite a bit.
    - does this amp have a toroidal power transformer? If so, the cause may be DC offset on the AC power line. Toroidals are very sensitive to offsets and can saturate in one direction from a trivial offset.
    - does the amp do this in another building?
    - Does the hum change with other tubes being pulled?
    - does the hum change with other controls being changed?
    If the answer to the above is all "no", there are a few other things to check.
  14. #14
    Dec 2008
    Wernersville, PA
    12,104
    Where are you "scoping" the buzz?
    The output at the dummy load?
    If so, work your way back into the preamp.
    -Is it riding on the B+.(check all of the preamp plate nodes)
    -Is it riding on any of the grids.
    -Is it riding on any of the cathodes.
  15. #15
    Oct 2011
    54
    This is great! I am receiving a lot of nice helpful advice. Thanks to everyone!
    I measured both sides of the heater voltage wires (referenced to ground) and balanced the voltage to 3.14 Vac on each side to verify the control is functioning normally. This did not resolve the undesired buzz so I then listened to the amplifier and adjusted the hum control to provide the best “null” as per the Owner’s Manual (minimal adjustment was required).
    Someone asked: “does this amp have a toroidal power transformer?” Answer: No. It is your typical iron core transformer (I don't think Fender uses Toroidal transformers in any of the 65 Twin Reverbs).
    Someone asked: “does the amp do this in another building?” Answer: This will be very difficult to try right now as the amp is disassembled on my bench. However, I did plug the amp into another outlet on the opposite side of the room with similar results.
    Someone asked: “Does the hum change with other tubes being pulled? Answer: Yes. When V6 is removed, the buzz disappears (previously mentioned in this thread)
    Someone asked: “does the hum change with other controls being changed?” Answer: No. (previously mentioned in this thread)
    Someone asked: "Are you sure that the valves that you used are matched pair?" Answer: Actually, this amp requires four valves. I installed two sets of matched pair Mesa Boogie output tubes. One matched pair was installed in the V7 and V10 positions, the other matched pair was installed in the V8 and V9 positions. Measuring across the 1 ohm resistor from cathode to ground, the current varies slightly between tubes 50mA +/- 4mA. The plate voltage is 426 Vdc thus producing about 21 Watts each from each valve. Incidentally, how much variation in cathode current is considered acceptable between valves?
    Someone asked: “Where are you "scoping" the buzz?” Answer: ‘Scope measurements were taken at the speaker jack (with 4 ohm dummy load) - as mentioned at the beginning of this thread.
    As suggested, I will take measurements working my way back toward the preamp stages. I will be sure to check grids and cathodes as well.
  16. #16
    Sep 2010
    123
    Assuming you have normal 120-125 VAC line voltage, 426 volts on the plates is kinda low. I work on Lots of these Fenders. That makes me think something is pulling the voltage down and that might have something to do with your buzz/hum. I would take a good look at the power supply. You can start by just measuring the VAC on the plate supply filter cap with the amp at idle. More than 2 VAC is usually indicative of a problem. I would do the same for the screen voltage supply. VAC should be way low on that, in the order of 100-200mA
  17. #17
    g1
    g1 is offline
    Feb 2010
    9,763
    I was thinking the same thing about the B+. My gut feeling is it's still biased pretty hot. Don't get hung up on the 70% thing. There are many who suggest 60% max. or even 50% when plate voltage is in the 420 or more range.
    The schematic shows 440 plate volts, you might try aiming for that with your bias adjustment.
    And on the bias topic, it was stated earlier that the power tubes were biased at 38watts. If that is the case and it was like that for long, I would be concerned about the kind of shape those tubes are in.
    Matching can have a big impact on hum, but your numbers sound fairly close. In the silverface twins with the "output matching" rather than bias controls, the setting of the pot had a big impact on the hum level.
    Also, there are notes in the schematic about the settings when adjusting the hum pot. (open plug in J3 etc) If you didn't use those settings, give it another try.
    Certified Dotard
  18. #18
    Oct 2011
    54
    “DynaFreak” makes me think of the great Dynaco products.
    “g-one” make me think of aviation. You must be a pilot.
    I set the voltage supply to 120 VAC with my trusty Variac when making bias adjustments/measurements. On a separate note, I will check the voltage at pin 3 with output tubes removed (to see if they are excessively loading the P/S). I didn’t think 426 VDC would be considered low when compared to 440 VDC. But I trust you guys and this variance may be considered large for those with good valve experience.
    I have often wondered how much AC is acceptable in a guitar amp power supply. Would it be safe to use a “rule of thumb” anything over 0.5% could be considered to much AC for the plate supply and .05% for the screen supply?
    I agree, biasing output tubes at 60% of their max value may be a good idea when dealing with plate voltages over 420 VDC.
    Because these tubes were previously biased to 38 Watts each (well above the maximum dissipation) , they may have been compromised and will be replaced.
    Excellent catch! An open plug at J3 is used when adjusting the hum pot. I need to go back and verify the pot is adjusted correctly.
  19. #19
    g1
    g1 is offline
    Feb 2010
    9,763
    Nope. g1 is that part of a tube commonly used as the input. I'm fairly surprised no one else here uses tube nomenclature for their user names. One of the best laughs I had was when someone on this forum called me g-spot. Not sure if they were joking or preoccupied.
    I think ripple percentage will be much higher than that, maybe 5 to 10 percent? Maybe others here will have more exact numbers for max ripple at idle and at full power.
    Certified Dotard
  20. #20
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,357
    I got no ripple rules, but certainly a lot higher than 1/2 a percent.
    In a push pull output stage, B+ ripple tends to cancel, so the initial B+ node, which usually only goes to power tube plates, can be kinda sloppy. 450VDC? In percents, maybe a percent or two, so 5-10VAC maybe. Unless I have cause, I don;t usually measure it. By the screen node, I pretty much expect clean DC. Almost no ripple on the screens. And certainly none at all on the small tube nodes. The "filter caps" on the nodes after the first two are really there more as decouplers than filters. I reserve the term "filter" for ripple smoothing duty.
  21. #21
    Oct 2011
    54
    Mystery solved!
    C35 (a filter capacitor in the negative 65VDC supply) had one leg that was not soldered. Once the capacitor was properly soldered, the amp stopped “buzzing”. Thanks to everyone for their helpful comments!
  22. #22
    Dec 2008
    Wernersville, PA
    12,104
    Now why didn't I think to ask that?
    Glad you got it.
    That's what counts.
  23. #23
    g1
    g1 is offline
    Feb 2010
    9,763
    All this talk of bias and ripple and I couldn't put the two together and ask "did you check the bias supply for ripple?" Doh!
    Thanks for the update.
    Certified Dotard
  24. #24
    Dec 2008
    Wernersville, PA
    12,104
    Must of been napping in that class
    Rule #1: Check the power supply.
  1. Trouble shooting Silvertone twin twelve, squeal
    By music*child in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-14-2013, 12:16 PM
  2. trouble shooting a Princeton Reverb Reissue
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-24-2012, 02:49 AM
  3. 65 Fender Twin Reissue - No Reverb
    By tommyg in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-21-2011, 04:10 AM
  4. Musicman trouble shooting has caused hum, and only hum.
    By Gaz in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-10-2009, 12:53 AM
  5. Twin Reverb 65 RI - Reverb Hum
    By pickles_man in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-22-2008, 10:58 PM
