| | #1 |
| Junior Member Join Date: Apr 2007
| space echo dying
i've had my trusty re 301 for a couple of years now, replaced the tape a couple times, never demagnetized the heads, haven't been the best dad to it... could be cleaned up etc. but recently, it became a one-speed. a slow speed. the motor doesn't respond to my changing the echo speed knob at all. switching b/n different delay modes will get a little variation, but the motor still spins at the same speed. is this something that i can crack the homie open and fix myself? do i need a replacement motor? what da dill? thanks much for any insights. rene |
| | #2 |
| Senior Member Join Date: Jul 2006
| check motor bearings
I haven't got the schematics for that but I read a post once saying the bearings needed replacing and that the motor is impossible to get. Does the motor seem stiff when rorated by fingers? Its more probable the control circuitry has failed in which case a tech with some knowledge should be able to fault find. is this the motor? Sayama pioneer electronics D.C. Brushless motor Type M-502E-B02 24 volt lot 8L11 I'll attach 2 schematics of an earlier version the 201 which I gather had the same motor. They may be helpful to a tech to fault find yours, or at least start some more discussion... |
| | #3 |
| Senior Member Join Date: May 2006 Location: Near Seattle, WA, USA
Been a while since I've seen the inside of one of those, but one thing that comes to mind is to check the pinch roller for ease of rotation. I've seen them get pretty tough to move after sitting for a while, as the grease turns almost solid. There are probably some electrolytic caps that are getting pretty dried out inside by now too, and not just the big ones. Some far-gone caps on the motor drive board might be possible... Good luck! |
| | #4 |
| Junior Member Join Date: Nov 2007 Location: Austin, TX
My RE201 had the same problem. Turned out that the repeat rate pot had shorted to ground. I cleared the short and it has worked fine since. Well....mine's really hissy but that's another thread.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| space echo repair....no echo! | bmac | Music Electronics | 6 | 04-07-2007 01:33 AM |
| Roland Space echo | drewl | Maintenance, Troubleshooting & Repair | 8 | 03-31-2007 06:00 PM |
| Unicord/univox Ec-100 Tape Echo No Wet Sound | methodofcontrol | Guitar Effects | 13 | 03-06-2007 12:47 PM |
| Indy-metro help with dying NTFS HDD | Don Symes | Fun with computers | 16 | 02-09-2007 03:49 AM |
| Roland Space Echo | JC@ | Maintenance, Troubleshooting & Repair | 4 | 06-22-2006 12:34 PM |
