Originally Posted by
Mars Amp Repair
hello folks,
I have an Alesis ADAT II model LX20 that I am attempting to repair. In the '80s & 90's I was at the journeyman level of VCR/camcorder repair, so this is not a complete mystery to me by any stretch.
We just didn't get involved with the DAT stuff.
I get an 'error 7'when trying to play the tape which indicates that the video heads need cleaning.
I know their clean as I have monitored the RF output from the heads & it's there as well as looking with a very strong magnifying device I used back in the day...but, there is missing data at the exit side of the drum assy just before head switching. The tape path alignment is correct as I cannot get that part of the envelope to expand by increasing the back-tension slightly (by hand) or by slightly moving the exit guide post.
What I've come up with is that the tape supplied was recorded this way. The tape is not physically damaged, either.
Next problem I have I have no source for either a good prerecorded SVHS ADAT tape.
what also is a bit confusing is that the unit has the ability to record the Time Code on the fly or by pre-formating the tape. Even when I try that, while recording I still get the same error indicating the video heads are dirty. I can still see the playback RF while the unit is attempting to record. I'm not familiar enough with how the unit records the TimeCode to know if it does it with the stationary head or with the video heads in what might be considered the Vertical interval, like VHS does.
Does anyone have any insight or know a source for this kind of just technical operation for the ADAT type II format?
Thanx, glen
