Results 1 to 3 of 3
Thread: Primary Z early Portaflexes
    Senior Member Chris / CMW amps's Avatar
    Vleuten, The Netherlands
    111
    Question Primary Z early Portaflexes
    Hi all
    Due to some requests I need to know a little more about the early, cathode biased Ampeg Portaflexes;
    - primary impedance OT
    - B+ voltage (440V on a '64 according to the schematic, each 6L6GC biased at > 28 Watts...)
    - treble-control, 4M on the early schematics, 1M on the later ones. Where to get 4M pots?
    - pre or post 2nd stage EQ?
    Any experience, story, etc. is welcome. I've only seen and serviced SVTs and V4Bs over here in the Netherlands.
    Many tia!!!
    Love, peace & loudness,
    Chris
    http://www.CMWamps.com
    Lifetime Member Rob Mercure's Avatar
    Wise, Virginia
    624
    Hey Chris,
    From the "4/69" factory B-15N service manual:
    OT-214, 6.5K primary, 8, 16 ohm secondary, 290 ohms pri. DCR, 1, 1,4 ohm secondary, stock # 8950-012
    6L6GC outputs: Ep+450VDC, Eg2+445VDC, Eg1-50VDC (fixed bias model, best I've got)
    This one has the EQ after the 2nd stage - all 6SL7 signal level tubes.
    And I've got one of these myself and it sounds really great - wonderful bass from the 15" JBL and actually nice, in a boomy way, with my '60 Strat. I'm not sure that cathode bias would improve this but who knows?
    PI is an "anode follower" driven from unequal divider resistors.
    And despite what you may have read elsewhere the Ampeg, of Linden, NJ, rated these beasts at "70W peak, 30W RMS."
    Rob
    111
    Hey Rob
    Many thanks, it does certainly give me some more info about these bass-classics.
    Greetings from the (now) sunny Netherlands!
    Chris
  1. Early 70s Ampeg V2 found in the trash
    By Ampeg Student in forum Vintage Amps
    Last Post: 10-06-2010, 12:04 AM
  2. Primary impedance for 4x6L6?
    By Hallingamp in forum Theory & Design
    Last Post: 05-09-2007, 03:59 PM
  3. Mission 5E3 breaks up very early
    By Henk in forum Tweed Builders
    Last Post: 03-20-2007, 04:11 AM
  4. Early 4X12 Cab
    By kramps in forum SUNN
    Last Post: 11-18-2006, 11:59 PM
  5. Failed primary winding on Power Tranny?
    By hasserl in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-01-2006, 01:48 AM
