| | #1 |
| Member Join Date: May 2007
| Magnets- Output, Tone, etc.
Could somebody explain why ceramic magnets produce a hotter p/up? Is it a higher gauss, or the material they are composed of or something else? If its a matter of gauss, could an alnico magnet be charged to the same level as a ceramic and provide similar output while still retaining its own characteristic sound? Also, I have read somewhere the slug pole pieces in a humbucker tend to have slightly more output, is this due to their having a bit more mass than the adjustable poles? If so, is there a way to equalize them without adding more winds to the one coil? One more question (sorry)- if you took a humbucker, did away with the bar magnet, and had two bobbins drilled for slugs and put alnico-2s in one bobbin, 5s in the other, and charged them, would it result in a kind of blended tone, or not really work at all? |
| | #2 | |
| Quote:
It would result in a blended tone and would work, make one set of rods north up and the other south up just as you would have the screw side south and the slug side north or visa versa depending on how you do it, south on the screw side seems to be the norm. Hope this helps and please anyone jump in and correct any mistakes I have made... | |
| | #3 | ||||
| Quote:
Quote:
Quote:
Quote:
| | #4 |
| Senior Member Join Date: May 2006 Location: Cornelius, Oregon
I have a custom Wolfetone pickup in my Strat with A5 magnets for the bass strings and A2 for the treble strings. It is around 8.5k DCR with 42 and sounds great. Greg |
| | #5 |
| Yes, mixing Alnico rods in a Strat pu will work too. The first I heard of it was Duncan's Five-Two, which is just what you described, except the coil is vintage ranged, low 6's or so. I've made a couple of "hybrids" myself, including one in the mid-8's. One was A5 and A3.
| | #6 |
Yah, lots of guys do the five/two thing...I think Fralin does too. Do you notice much of an output difference with the five/three pickup? Or do you degauss the five down to fit better with the three? Greg |
| | #7 | |
| Quote:
The A5's don't make the wound strings sound louder than the A2/A3's on the plain strings so much as they just sound clearer and brighter. Some snap and twang is there that's otherwise missing. So the thing I noticed about the 5/2's and 5/3's I've made is that for the first time it sounds like all 6 strings are from the same guitar. | |
| | #8 |
Thats cool. I noticed the same thing with my Wolfetone 5/2, but I didn't think of trying a 5/3 because I figured the much weaker 3's wouldn't keep up. Nice to know theres a benefit to it.
| | #9 |
| Junior Member Join Date: Jan 2007
I have tried an A2/A5 bucker just like you mentioned! I was fired up with the spirit of discovery! A few pointers 1. Using standard humbucker bobbins may not be the ideal thing. 1/4 coil height and alnico poles arent really ideal. Think about using Forbon and a 3/8 coil height. It will sound better split too. 2. If you have good ears, or even mediocre ears like me, you will hear a definitely two-track sound going on. You can literally hear both of the coils working. This is pretty strange as you would think that the their signals would be summed up in series, but the truth is that you have two seperate attacks and two seperate decays going on. Kind of like playing with a harmoniser without a pitch shift. 3. I didnt try listening in parallel, but wish I had now! |
| | #10 | |
| Senior Member Join Date: Jan 2007 Location: Stockholm, Sweden, Europe, Terra Nostra
| Quote:
| | #11 |
| Member Join Date: Oct 2006
I make a custom bucker similar to what Andrew described. I use two custom forbon bobbins and alnico rods. All mounted to a bucker baseplate. It's tone is very 3D and splits are incredible. |
| | #12 |
| A3 isn't significantly weaker than A2 in terms of output. The tone is ever-so-slightly brighter/thinner but the output is almost identical. Might be the better choice for the high strings if you're going for an overwound mix-mag Strat pu.
| | #13 | |
| The Immoderator Join Date: May 2006 Location: NYC Metro
| Quote:
magnets have TWO major properties that determine their usefulness: attraction and resistance to demagnetization, summarized as pull and push-back, I suppose. For more info, the pull and push attributes are called remanence (Br) and coercivity (Hc). Alnico pulls strongly, pushes back weakly. This means that alnico magnets near each other tend to demagnetize and, if they are cut too small on their magnetic axis, they again tend to demagnetize. Because of the weaker push-back, you get compression effects with Alnico 2 compared to Alnico 5, and with ceramics compared to alnico's if everything else in the pickup stays the same (which is never). Ceramic mags pull weakly but push back strongly. They are harder to demagnetize and, up to a certain size, pull more strongly than alnico. This translates to a hotter pickup with a high dynamic range and better high frequency output. If you magnetized alnico only to ceramic levels, a pickup would not sound like a ceramic mag version because the push-back attributes are so different between the magnets. That doesn't mean it will sound bad, though. -drh | |
| | #14 | |
| Quote:
greg | |
| | #15 | |
| Music Lover | Quote:
Zen bliss... S. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Magnets in the U.K. | Sock Puppet | Pickup Makers | 7 | 08-23-2007 10:04 AM |
| Cast magnets | Matt T. | Pickup Makers | 24 | 01-12-2007 01:30 AM |
| How do I calibrate magnets? | twogeez | Pickup Makers | 0 | 10-29-2006 09:00 PM |
| humbucker magnets | franklin01 | Pickup Makers | 6 | 10-14-2006 10:49 PM |
| what magnets can i use??? | franklin01 | Pickup Makers | 0 | 08-21-2006 02:51 PM |
