Results 1 to 4 of 4
Thread: Western Digital Bolognese
    May 2011
    Manchester UK
    60
    I have learned two things today:
    1) A really good way to slowly defrost a bag of minced beef is on top of an overheating hard drive.
    2) A really good way to keep a failing hard drive running long enough to migrate your data is with a bag of frozen mince.
    I was brought an iMac to fix and upgrade. I eventually managed to get all the customer's information off the original WD 250GB hard drive. I couldn't do this with a drive imager as it wouldn't run for long enough. The hard drive would only run for 25 minutes or so before clicking and spinning down. It would then come back to life for increasingly short periods. I soon discovered that giving it a rest to cool down, would give me a longer burst of data recovery.
    Having got the data safe, I tried some drive utility software to see if the drive data structure could be repaired. It came as no surprise that it couldn't as what was clearly a thermal/mechanical fault had caused the drive corruption.
    I fitted a new drive and installed a fresh OS and a bit more RAM for good measure. As the rescued data was just copied, it was not seen as a valid OS with valid users by Migration Assistant. I was either going to spend many hours cobbling all the applications and user information into the right places or find a way to make the original drive run continuously for 3 hours or so. That's where the frozen mince came in. I protected the drive with a plastic sheet and turned the bag of m round regularly to a fresh cold patch. The drive data all migrated perfectly.
    Not only was the repair a success, the "spag bol" was excellent.
    Martin
    Supporting Member Steve A.'s Avatar
    1,465
    Is minced beef the same as ground beef in the US, used for hamburgers and meat loafs?
    Thanks!
    Steve Ahola
    Capacitater Steve Conner's Avatar
    Glasgow, Scotland
    6,846
    Yes, we call it simply "mince".
    In the north at least, they might call it something different down in London.
    May 2011
    Manchester UK
    60
    I had a feeling this might drift away from computers....
    Yes, but we have mince beef and ground beef. I think the ground is minced somewhat finer. I would use that for filling a tortilla, but use the coarser mince for spag bol and burgers.
    Mince
    Ground
    Martin
  1. Peavey Digital Reverb
    By Billy R aka DynaFreak in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-18-2012, 07:36 PM
  2. Digital pots using relays
    By loudthud in forum Theory & Design
    Last Post: 11-08-2011, 09:21 AM
  3. Digital Counter Idea
    By tonedeciple in forum Tools and Coil Winding Gear
    Last Post: 02-20-2010, 02:47 AM
  4. Digital amplifiers
    By Enzo in forum Music Electronics
    Last Post: 10-23-2007, 02:53 AM
  5. Mini digital reverb?
    By Steve Conner in forum Guitar Effects
    Last Post: 02-04-2007, 11:45 AM
