Go Back   Music Electronics Forum > Amplification > Other Amps
Old 05-06-2007, 01:36 AM   #1
Magnavox phono console -> Guitar amp
I bought an old Magnavox phonograph console for $30 today, for the tubes if nothing else. The turntable section is worthless, so I wired a guitar through it and it
sounds surprisingly good.
This thing powers on when the tonearm/turntable is engaged. There is no ON/OFF switch otherwise. As you can imagine, I'd rather not have this clunky carousel spinning around, as it adds unnecessary noise to the
unit.
There are three seperate stages in this thing. The power amp (2 x 5Y3, 4 x 6v6, 1 x 12AX7),
a seperate tone box (1 x 6AV6), and a preamp (1 x 5Y3, 2 x 6V6, 1 x 6AN8). All the tubes work
fine - old Magnavox and RCA tubes, two ten inch speakers...
So, my question is this: the turntable motor runs off the power transformer in the
pre amp section. I'm assuming I'll add the standby and power switch somewhere in this area.
There are three wires running from the preamp to the motor. If the connection between
the power transformer and turntable motor gets disconnected, what should I do with these leads? Maybe the more general question is what to do with unused leads so as not to ruin the transformer.
Naturally, there was no schematic with this thing and no user's manual.
Any ideas?
ZBod is offline   Reply With Quote
Old 05-07-2007, 02:06 AM   #2
Do you mean that the turntable will not play a record?
Arthur B. is offline   Reply With Quote
Old 05-07-2007, 03:07 PM   #3
Lifetime Member
Rob Mercure's Avatar
Any unused leads should be safely insulated and taped out of the way. While you state the turntable runs off the power tranny I suspect that the turntable is directly powered from the mains - there is probably a switch under the turntable deck that feeds power to the PT and turns the amplifier off (on) when the record reaches the inside leader track.
Your tube lineup is a bit odd with far too many output tubes and too few "preamp" tubes. Although there are sufficient stages for split load phase inverters you've still got at least two different output sections - probably one more than you'll need. Concentrating your work on the section that most interests you would allow you to focus on tweaking up the "tone machine" of your dreams - the 6AN8 section probably lends itself to a "Deluxish" tone monster.
Rob
Rob Mercure is offline   Reply With Quote
what is this guitar? NightWinder Pickup Makers 8 02-10-2007 08:26 PM
stromberg pa to guitar amp scole Build Your Amp 3 01-16-2007 12:10 AM
Guitar Parts USA FYI Mystic Pickup Makers 14 11-29-2006 06:50 PM
Console Power Supply modules Matt R Music Electronics 3 09-12-2006 04:24 PM
Reconfigure Phono preamp for other use ... Todd Hepler Other Amps 3 06-10-2006 06:28 PM
