Results 1 to 15 of 15
Thread: 18 watt TMB build,no sound?
    Dec 2009
    canada
    393
    Hey guys, I just finished up a 18 watt TMB build and when I powered it up everything lights up,ie;indicator light,tubes etc but i have no sound.
    checked the speaker,speaker cable,input and output connections and it all seems to be fine. Can't seem to track down the reason for it. any help would be greatly appreciated.
    Chuck.
    Supporting Member
    Jul 2007
    So. California
    876
    No sound at all, not even a slight hum or noise of any kind?
    Dec 2009
    canada
    393
    Quote Originally Posted by JoeM View Post
    Hey joe,no nothing.
    May 2007
    pacific north west
    5,890
    Voltage reading at the tube pins???
    "I should have been born sooner. Of course, if I had been, I might be dead now." trem
    Dec 2009
    canada
    393
    Quote Originally Posted by Chuck H View Post
    Hey chuck I tried taking some voltage readings and everything comes back a negitive reading,even the B+.
    Some examples of readings I've taken are;
    V1-pin 1=-0.979vdc
    pin3= 13vdc
    pin 6=-1.027vdc and dropping.
    pin 8= -0.005vdc
    This is consistant on all the tubes, all negative readings?
    Chuck.
    Dec 2009
    canada
    393
    I'm using a separate 6.3v transformer for the rectifier tube as the trannys I'm using doesn't have a seperate winding for the rectifier.
    Chuck.
  7. #7
    Supporting Member loudthud's Avatar
    Near Dallas Texas
    2,096
    Link or post a schematic please.
    WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
  8. #8
    Dec 2009
    canada
    393
    Quote Originally Posted by loudthud View Post
    hey loudthud, I'm using the ceriatone 18watt TMB schematic but I haven't got one on file to post. I have the layout which i have gotten from the ceriatone website,if that helps.
    chuck.
  9. #9
    May 2007
    pacific north west
    5,890
    Something in the power supply (at least) seems to be miswired. But do check the HV secondary voltages.
  10. #10
    Dec 2009
    canada
    393
    Yes chuck, That's what i was thinking. The power tranny has windings for 120v and 240v but I wasn't to sure how they were wired for 120v. Here is what is printed on the power tranny;Input: BLK-Blue - Orange Brown-yellow
    fuse-100v- 120v fuse - 120v
    Output: 266vac @150ma (red)
    27vac @ 100ma (Vio)
    6.3vac @ 200ma (wht)
    I have the orange and yellow wired together on one side of the on/0ff switch.The other side of the on/off switch goes to the end lug of fuse.
    I have the brown and black wired together on one lug of the IEC terminal. The other lug of the IEC socket is wired to the center lug of the fuse. The center lug od the IEC socket is wired to ground.
    I suspect I have it wired wrong though.
    Chuck.
  11. #11
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    1,241
    Quote Originally Posted by chuckb View Post
    27vac @ 100ma (Vio)
    Chuck.
    I thought you said you had no filament winding?
  12. #12
    Dec 2009
    canada
    393
    Hey chuck, i'm sorry about that but I didn't think that the winding I had was sufficient for the rectifier as well so I added anothe seperate 6.3v tranny for that.
  13. #13
    Dec 2009
    canada
    393
    Hey chuck,I thought I needed a separate winding for the rectifier?
    chuck.
  14. #14
    May 2007
    pacific north west
    5,890
    That was olddawg who asked after the filament supply. I read that your using another tranny for that. And rightly so since I don't even know what a 200mA 6.3V tap is good for.?. Since your tubes are glowing let's ignore that tranny for now.
    As to the primary wiring, not much info in your post. What you say is written on the transformer regarding the primary just looks like color names without designations to me. And there aren't any absolute standards either. Do you know the transformer MFG? Where did you get it? You already tried turning the amp on and it seems nothing blew up. So is there HV on pins 1 and 7 of the EZ81?
  15. #15
    Dec 2007
    1,241
    Sorry guys. I thought the 6.3v @ 200ma was a typo. Just trying to simplify things, wondering if the filament was working at all. The standard HV secondary for an 18 watt clone is around 290-300v.
  1. Which 12AX7 for my 18 watt plexi build ?
    By copperheadroads in forum Tubes (Valves)
    Last Post: 04-19-2012, 11:02 PM
  2. 18 watt TMB?
    By chuckb in forum Debugging Your Build
    Last Post: 03-14-2012, 12:30 AM
  3. First Build - Marshall 18 Watt build troubles
    By bandade in forum Debugging Your Build
    Last Post: 08-13-2010, 12:54 PM
  4. 36 watt tmb lite half power
    By marcrochotte in forum Music Electronics
    Last Post: 12-07-2009, 01:39 AM
  5. New SE 18 Watt build
    By mooreamps in forum Theory & Design
    Last Post: 06-13-2007, 02:40 AM
