Results 1 to 32 of 32
Like Tree1Likes
  • 1 Post By Enzo
Thread: Peavey Bandit (1981) loud hum
    Apr 2012
    11
    I have a peavey Bandit made in 1981 (the one before the 65) and when i turn it on there is a loud constant hum from the speaker.this happens when all knobs turned to zero and nothing pluged into it,and nothing changes to the hum when knobs are turned up or down.did notice the speaker moves outward and stays there. any help on this would be great.
    Attached Files Attached Files
    Jun 2007
    2,716
    Quote Originally Posted by JimmyTolson View Post
    Welcome to the place. When the speaker pushes in or out and stays there, that means that the amp has a fault that is putting dc voltage across the speaker terminals. Do not leave the amp on with the speaker connected, as it will cause damage to the speaker.
    This problem is usually an indication of a failed output transistor in the power amp. What sorts of skills do you have? Is this something that you can fix yourself?
    Apr 2012
    11
    hi and thanks for the welcome. i'm not a amp repairman but can figure things out pretty quick.i posted the schematic in hopes someone could point me in the right direction.it has the schematic plus a drawing of the location of the electronics on it.i have a pretty good testing meter for testing and all electonics stick through and sorder to the backside of the board.
    added pics of the amp's board. the 4 items in the last pic i changed as told but there was no change in hum or speaker standing out.
    Attached Thumbnails Attached Thumbnails 101_0554.jpg   101_0553.jpg   101_0555.jpg   101_0556.jpg
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,537
    Just to elaborate on the DC on the speaker thing.....the speaker can also suck in and stay there. That would indicate the output section stuck to the negative rail (providing the speaker is wired with correct polarity).
    Apr 2012
    11
    speaker is wired right reguarding polarity and goes outward and stays till amp is turned off then it goes back to where its suppose to be.
    on another forum about steel guitar amps they change the op amps in there mods to the bandit to these " OPA2134PA Texas Instruments Op Amps " would these help my problem.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,025
    No No No.
    The amp needs repair, NOT modification. They may like those other op amps better for whatever reason, but the fact you have the standard op amps is not what is wrong here. FIX the amp first, THEN think about any changes you want to fiddle with.
    In other words, if you are in the emergency room with a massive heart attack, then is not the time to suggest plastic surgery to your nose.
    If you have already replaced the power transistors, we also need to check the drivers, and they are the smaller transistors on their own little 8-finned heatsinks. Without me looking, I think they are probably 5331 and 5332 types. Not only that, make sure none of those rectangular tan cement power resistors have gone open. And look in the schematic for resistors associated with those drivers, PV likes to use 47 ohms a lot. See if any of those are open.
    Make sure both positive AND negative power supplies are present. And I mean both the 15v ones for the ICs, and the higher voltage ones for the power amp. A missing -40v can slam an output to +40 just as easily as a shorted +40v transistor can.
    DrGonz78 likes this.
  7. #7
    Nov 2007
    Owosso, Mi
    1,537
    ^^^What he said^^^
  8. #8
    Oct 2007
    Buenos Aires, Argentina
    4,471
    And *DISCONNECT* that speaker NOW.
    Also search for "bulb lamp limiter" , build one and use it.
    Plug your amp into the current limiter until it's fully repaired.
    It will save you $$$$$ and bad mood.
    And follow all of Enzo's instructions, they are meant to drive you safely to a happy ending.
  9. #9
    Apr 2012
    11
    @ENZO I wasnt meaning modification but more to would those cause the hum.I'll check the things you said to and post back,thanks for everyones help on here.
  10. #10
    18,025
    Ah. Well, no, different op amps wouldn;t cause hum. They might increase or decrease noise, as in hiss.
  11. #11
    Apr 2012
    11
    Is there a replacement part # for the rectangular tan cement power resistors that i can get from Mouser.
    they have " cp-5-25 Dale 5w
    400u 10% 8136
    and " cp-5-25 Dale 5w
    .33u 10% 8136
    and " cp-10-25 Dale 10w
    .22u 10% 8103
    thanks again.
    also on the resistors they are 47 ohms is there a part # for these i can get from mouser.
    altho i replaced the 2 larger caps on the board with ones i found at radioshack 2200 50v is there a better one to replace it with i can get from mouser or are the ones i put in it alright.
    dont mean to agravate with questions but where you guys work on these alot thought u might already know.
  12. #12
    Dec 2008
    Wernersville, PA
    5,369
    Are the resistors 'open'?
    You can get just about any Peavey part direct from Peavey.
    Great people to work with!
  13. #13
    Apr 2012
    11
    no there not open but getting from mouser is easier for me as im not to tech savvy and peavey may mis understand me.
  14. #14
    18,025
    Agreed, if the resistor is not open, it is OK.
    Mouser stocks them all. These are wirewound power resistors. If you enter CP5 in their search window then select resistors under the passive parts section, you sill find them. 0.33 ohm will be listed as 330mOhm and 400 ohm they have too. You can also search CR5 for very similar parts. In the CR line they stick to standard values, so the 400 ohm would have to become 390 ohm.
    I have never seen that 10 watt 0.22 ohm one open before. But search same way for it, except looking for CP10.
  15. #15
    Dec 2008
    Wernersville, PA
    5,369
    Why are we replacing good resistors?
    Was the initial fault ever located?
    Like maybe shorted output transistors.
  16. #16
    Apr 2012
    11
    on the 3 47ohm resistors (the small brown ones with strips beside the heatsinks) in line with the output transitors, 2 show 0.00 on the ohm meter while one moves up and down in the numbers but slow. all are still mounted to the board tho. if this one is suspected being bad what would the part number be on mouser.i agree with Jazz p bass on the shorted output transistor but thinking the one little 47ohm one may have caused it.
  17. #17
    Dec 2008
    Wernersville, PA
    5,369
    Generally speaking, resistors do not 'cause' failures.
    The 47 ohm resistors that you are referring to will burn up if the output transistors go shorted.
    Testing them in circuit can be misleading as other parallel paths exist.
    The one that shows '0.00' is most probably pointing to a shorted transistor.
    Labeling the parts that you want to talk about is a good idea.
    You can use the part designator that is labeled on the schematic.
    Can you please list the test equipment that you have available?
    The transistors can be checked with a decent multimeter.
    Preferably one with 'diode check' function.
    If you do not know how to check a transistor, Google it.
  18. #18
    Apr 2012
    11
    Okay i changed the 3 driver transitors 5331 and 5332 + bought new output transistors to make sure i had the right ones and there is no change in hum or speaker standing out. i made the lightbulb limiter as suggested to hook between amp and electric and without the speaker hooked up the lightbulb glows real dim but when speaker is hooked up lightbulb glows bright.the 3 resistors that are beside the little heatsinks beside the driver transistors (2 on one and 1 on the other) all check out to 47ohms.
  19. #19
    Dec 2008
    Wernersville, PA
    5,369
    Now it's time to take some voltage readings.
    With the amp hooked through the limiter & the speaker disconnected.
    Look at the schematic.
    There are test voltages galore.
    What you want to find is something way abnormal from the schematic voltages.
    It may help if you keep in mind what this output section is doing.
    It is a balancing act between the + & - rail voltages.
    The output transistors should be seeing around .500 - .600 volts on there bases. In other words 'barely' turned on.
    That will place the driver transistor bases at around 1.1 volts.
    Start there.
  20. #20
    Jun 2007
    2,716
    Have we ever found out how much and what kind of voltage is on the output of this amp?
    I'm really afraid that if Jimmy keeps throwing parts at this amp there will be far more to repair than what was originally wrong with it in the first place.
  21. #21
    Jag
    Jag is offline
    Senior Member Jag's Avatar
    500
    I POSITIVE he's going to be buying a new speaker soon!
    As 52Bill said in the very first response to your question
    Seriously, DON'T connect the speaker until you have resolved the problem. If you want to know if there is still DC at the output, use a meter to check NOT the speaker!
  22. #22
    Senior Member DrGonz78's Avatar
    Oct 2011
    Phoenix, AZ
    418
    The DC on the speaker is the hum, so measure that w/ meter. Do not think that the meter will show something different than when you plug in the speaker to take a listen. Also, I was wondering if you had tested the rectifier diodes? In the original picture this diode looks funny to me... Probably just the shadow or something, but it looks chipped or something. I bet that is just the shadow, but I would still test those diodes. Also, test all your voltages foremost...
  23. #23
    Apr 2012
    11
    101_0570.jpg101_0564.jpg101_0565.jpg101_0567.jpgI looked at the rectifier diode you circled in the pic above and there is a raised line like crack on the side toward the edge of the board. the numbers are hard to read but it looks the same as the one below it and the 2 between the big blue capacitors. the 2 beside the white square thing are smaller with different numbers. ill post closer pics of it.( the meter pic is of what i have to check things with.)
  24. #24
    Oct 2011
    Phoenix, AZ
    418
    I have read a post of these diodes creating hum before and the guy had changed so many things before the rectifier diodes. To me it looks like there is maybe a crack in it and then someone put a dab of glue on it...? Not sure if that is what I am seeing here. Did you test the diode? Now if all the diodes have this hair line crack then that is how they will look, so make sure I am not leading astray. If it looks like more than hairline then I would probably be questioning that part more. I was just seeing something that was in the picture and that may(probably not) not be the problem here...
    Put your multimeter on the diode checking feature and test it both ways with the amp off. One way will read I or OL and the other will read .500 or .700 or something around those types of readings. My feeling here is that they are probably fine but you should always check. If you get funny readings then sometimes you need to lift a leg on a diode to pull it out of circuit to get definite readings. The fact that the amp is passing the signal to the output make me think that these are probably working just fine.
    Edit: Get on track w/ the light bulb limiter running the amp and get those output transistor voltage readings foremost.
  25. #25
    Apr 2012
    11
    i pulled one leg of the diode in question and checked it. one way does nothing on the meter as it stays at 1 and when i reverse the wires it shoots to 620. this is using the diode check on the meter in pic above (->l-) .
  26. #26
    Oct 2011
    Phoenix, AZ
    418
    So it looks good. Sorry to get you going in another direction, but that is good to know that the part measures correctly. How is it going w/ your voltage measurements? Let us know when you test those output transistors. Best regards
  27. #27
    Apr 2012
    11
    ive done everything to my scope on this and im having no luck at all.the nearest place to me is over a 2 hour drive one way that can even look at it. would be willing to u.p.s it to someone on here that knows about these amps to get it fixed. would be glad to pay plus pay for return shipping if anyone is interested.
  28. #28
    Dec 2008
    Wernersville, PA
    5,369
    You still have not posted any voltage readings.
    Basic stuff.
    Like the power supply rails, the base voltages of the output transistors.
    That would basically require a volt meter.
    (unless the scope was set to read Vdc.)
  29. #29
    Oct 2007
    4,471
    Quote Originally Posted by Motumoyo View Post
    If you enter the CP5 in their search window, then select the resistance of the passive component parts, and find them on your windowsill.
    Sorry Motumoyo, don't get you.
    What are you trying to say?.
    Thanks.
  30. #30
    Oct 2011
    Phoenix, AZ
    418
    In a galaxy far, far away... C3 PO and R2 D2 were in a search window trying to save us all from bots...
  31. #31
    Oct 2007
    4,471
    Yes, it *did* sound like "Botglish".
    But his earlier post about master volume sort of made sense.
    Yes, I also saw his manga-pushing signature.
    Which is about Samurai fighting Aliens in Medieval Japan.
    Swords against Laser and Nuclear weapons.
    Yea, sure, any day
  32. #32
    Oct 2011
    Phoenix, AZ
    418
    I actually have some spare parts sitting on my windowsill, so it was kinda of a moment where Botglish made sense too. I read his other posts and thought they were even better thought out. Isn't it funny how someone takes all this time to clutter up these boards as to gain a link pointing to their commercial websites. I understand why it helps search placement in google etc., but it is funny when they try to talk on topic. Not sure if it generated by string data that it collects from postings on this site or if someone actually typed that junk.
  1. Peavey Windsor head has Very Loud Hum
    By Coop in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-16-2011, 12:14 AM
  2. Peavey Bandit loud popping
    By ApeWeevil in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-29-2010, 08:26 PM
  3. Peavey Bandit Problem - Hum, no output
    By TeleTim911 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-17-2010, 06:58 PM
  4. Peavey Transformer 112; loud hum
    By md11foanc in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-30-2008, 10:03 PM
  5. Loud Hum In Peavey Pacer Amp
    By rickenvox in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-04-2008, 03:59 AM
