Results 1 to 4 of 4
Thread: Oliver Bias circuit
    Jun 2006
    Norristown state hospital
    929
    Oliver Bias circuit
    So I'm rebuilding this old Oliver G150, and it seems like a mixture of models.
    The power tranny looks like it's for a tube recitified model, when this one uses diodes.
    There was no bias tap, so they installed a little 6v-120v transformer inside.
    Think I should remove it, and just tap off the high voltage winding for the bias circuit like the tube rectified models do?
    I can alsways switch it back if there's a problem, but it just seems "messy" with this extra tranny inside.
    Oh, and the reverb driver is a 6DR7 I asked previously, it's what's used in other models.
    http://www.pmillett.com/file_downloads/oliver_amps.pdf
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,686
    Quote Originally Posted by drewl View Post
    You think you know more than the person who designed it? I don't think so.
    Sure you can tap off to supply bias, but what was the reason for doing it in the first place?
    Sure you can tap off to supply bias, but what was the reason for doing it that way in the first place?
    Jun 2006
    929
    Quote Originally Posted by soundguruman View Post
    Yes, Yes I do.
    After a few decades of repairing these 50 yr old designs, I've seen what works and what doesn't.
    Not positive it came from the factory this way, or maybe they ran out of the correct tranny that day, or seeing how they didn't sell too many of these it could very well be possible they used whatever they had lying around to get the order out the door.
    As I've heard in many places I've worked over the years, including military subcontractors "when in doubt, ship it out"
    Oct 2007
    Buenos Aires, Argentina
    4,570
    Does the PT have a center tapped HV secondary?
    If so, you can attenuate that voltage down to what's needed with a couple resistors.
    What's made in most Olivers shown in the .PDF.
    If only a single secondary, bridge rectified, you can't do that directly.
    Which one is yours?
  1. Oliver G150....6DR7 tube?
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-01-2012, 01:12 AM
  2. Bias Circuit Problem
    By mikeboone in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-29-2008, 04:57 AM
  3. Bias circuit problems...
    By Colonel_Sanders in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-18-2008, 10:05 AM
  4. bias circuit for 5F8A
    By Mouthurst in forum Tweed Builders
    Last Post: 04-30-2007, 07:34 AM
  5. Bias doubler circuit
    By Mars Amp Repair in forum Mods & Tweeks
    Last Post: 10-04-2006, 02:24 PM
