Results 1 to 4 of 4
Thread: Just getting started, what size pickups are best?
    Nov 2011
    2
    I am just getting started winding and want to buy some Humbucker, Stratocaster, Telecaster and P90 bobbins, plates, etc. My question is, what is the most common size for the bobbins for the various pickups? I am thinking of starting with all 50mm bobbins or, F spacing. I figure that if I can get a few units under my belt, I can special order more specific sized bobbins according to customer's (hopefully!!) requests.
    Any suggestions are welcome and thanks so much for your time.
    Lindsey
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,630
    Hi Lindsey:
    Depending on the guitar your winding for, Determines what is standard for that type of guitar.
    50mm will be fine for gibson type guitars.
    Fender type guitars are more F spaced.
    Here are some parts to look at to get ideas.
    Guitar Pickup Part by Type - Mojotone.com
    STEWMAC.COM : Guitar Electronics, Pickups, Pots, Switches, Caps, Shielding and Parts at
    Kits are the best way to get started.
    Mojo and Stewmac both have kits.
    Just pick the pickup type.
    Good Luck, and Welcome to the Forum.
    Terry
    Keep Rockin!
    Terry
    Nov 2011
    2
    Thanks so much for the information Terry. I am exploring all vendors and options. I like the idea of kits but I also want to experiment a bit. Might start with 4 or 5 kits and then jump off from there.
    Thanks again.
    Lindsey
    Jun 2010
    U.S.A.
    4,630
    Quote Originally Posted by lindsey9 View Post
    Thanks again.
    Lindsey
    I buy loose parts from Mojo, haven't tried their kits.
    I used the StewMac Bucker Kits.
    They are really good, but a little pricey.
    If you need wire, I like Remington.
    http://www.remingtonindustries.com/P.../Category/Wire
    T
    Keep Rockin!
    Terry
  1. Speaker size vs. Cabniet Size vs. Wattage
    By blueguitar in forum Theory & Design
    Last Post: 04-21-2012, 03:12 PM
  2. Getting Started
    By dan46n2 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-16-2011, 02:08 AM
  3. counters? (just getting started..)
    By other1152 in forum Tools and Coil Winding Gear
    Last Post: 06-10-2010, 06:48 AM
  4. How to get started with an oscilloscope?
    By bluesbreaker18 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-08-2009, 04:19 AM
  5. Size of the magnets for pickups
    By tiococo in forum Pickup Makers
    Last Post: 05-22-2007, 05:12 PM
Tags for this Thread
