Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Enzo
Thread: KLDguitar Power attenautor PB1
    Senior Member kldguitar's Avatar
    Jan 2008
    171
    Blog Entries
    2
    PB attenuator was designed to let you maintain your amp’s tone and dynamic response while keeping the overall volume under control. On stage and in the studio the PB gives you great flexibility for different volume levels. At home studio it can be used to really attenuate the overall volume down to 1 watt or less (amp less 100w)
    Top Controls:
    Attenuation: This is a rotary switch that selects the amount of attenuation. Mini position is true by¬pass. Positions 4-1 adds 1.8 dB of attenuation per click.
    Studio Level: A rheostat that will adjust the amp’s output from -7.2 dB down to -30 dB.
    Side Jacks:
    IN: Connect a speaker cable from this jack to your amp’s speaker out jack.
    OUT: Connect a speaker cable from this jack to your speaker cabinet. It is optimal to match your amp speaker out to the external speaker rating. (ex: 8 ohm speaker out jack on amp with 8 ohm speaker cab.)
    Enclosure:
    Al alloy case let PB attenuator dissipate heat easy.
    Weight : 1.8kg(unpacked)
    DEM: 162x74.5X250mm
    Clips http://youtu.be/2S7GNkAIxrA
    May 2007
    pacific north west
    5,909
    Nice demo vid. Looks like a good product. I think you know by now that the forum members aren't really in the market for your products because we build our own stuff. So I'll assume you just wanted to share your achievement.
    "I should have been born sooner. Of course, if I had been, I might be dead now." trem
    Oct 2007
    Buenos Aires, Argentina
    4,568
    Dear chuck h : I think KLD is showing it here because if I'm not mistaken, he "designed" it with the collective input of many MEF members.
    I still remember his endless string of questions.
    Fine with me.
    May 2007
    pacific north west
    5,909
    Yes, I remember that. For all I know it's just my simple attenuator in a fancy box (the description and operation leads me to believe it might be). Fine with me. I posted the design here to share with forum members full well knowing the design became public domain at that moment.
    Jan 2008
    171
    Blog Entries
    2
    Difference colors of PB 1 KLDguitar
    Please compare red PB1 with blue PB1, you can find it is importance that good color.Blue color let same thing nice . In many place , people pay attention to outlook of products more.
    May 2007
    pacific north west
    5,909
    The blue one is better for blues and the red one is better for rock got it!
  7. #7
    Jan 2008
    171
    Blog Entries
    2
    Good advice. It seems many people like blue in china. Certainly, I think color is important in design
  8. #8
    May 2007
    pacific north west
    5,909
    I was only kidding about the difference. But it's true that different types of players (and cultures) like different colors. Maybe that's part of why the Fender and Marshall amps did so well in history. They were BLACK. Black goes with anything.
  9. #9
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,253
    Sometime read The Hidden Persuaders, by Vance Packard. It is from 1957, but it still applies. It is about subliminal advertising and other consumer motivation techniques.
    One of my favorite anecdotes in it is about laundry detergent. They boxed the exact same laundry detergent powder in three different packages and gave it to housewives for trial. There were no brand names on the boxes, but they did have color schemes and designs. After a few weeks they asked the women what they thought about the three "different" laundry detergents. Fairly consistently, they found a lot of the ladies thought the soap in the red box was "too harsh" on their clothes, the soap in the blue box was OK but not really strong enough. And the soap in the yellow box seemed to be the best at cleaning clothes without any negatives. But it was the identical soap in all three packages. The power of the mind.
    SO we can joke, but it is true, color does matter, at least in terms of marketing. I bet if you make two identical 5E3 chassis and cabs, and dress one in brown tolex and oxblood grille cloth and another in traditional black tolex and black cloth, you will get more guys telling you the brown one seems to have a bit more of a vintage tone. Or take two 4x12 cabs, and dress one in nice black grille cloth ala Marshall cab, then do the other with those round steel waffle iron grilles bolted over each driver. See which cab the Death Metal guys think sounds better.
    Chuck H likes this.
  10. #10
    Senior Member Regis's Avatar
    Atlanta
    507
    Nobody thinks KLD actually designs anything do you?
    That KLD attenuator is a -6 and -12 db resistive attenuator.
    Gerald Weber published an article in Vintage Guitar a few years ago describing how to build one.
    Even if KLD didn't borrow/copy/steal/whatever the design, it's not exactly rocket science.
    It's just a couple of L-Pads cascaded one into the other. I'm a numbskull, and even I understand how to build one.
  11. #11
    Jan 2008
    171
    Blog Entries
    2
    hahaha, I think you are right. many people can do .But many people can not do it better and affordable .
    Our works let many people sharing music.
    Quote Originally Posted by Regis View Post
  1. kldguitar tube Booster effect pedal
    By kldguitar in forum Plug Your Product/Service
    Last Post: 06-27-2012, 05:21 AM
  2. kldguitar 100w guitar amp attenuator
    By kldguitar in forum Flea Market
    Last Post: 01-11-2011, 05:02 AM
  3. kldguitar supply tolex and grill cloth for customer
    Last Post: 01-01-2011, 01:29 PM
  4. kldguitar Freq Booster effect pedal
    Last Post: 09-14-2010, 06:18 AM
  5. kldguitar 50w guitar attenuator
    Last Post: 08-04-2010, 02:57 AM
Tags for this Thread
