There has been several threads on this topic lately.
Several things could be going wrong.
Make sure you bobbin is turning true with no wobble.
Don't use too much tension.
Check the wire stops, so the wire is staying inside the bobbin without flaring.
There are lots of posts and info like this in the beginners corner.
Be sure to search the forum before you post.
Good Luck,
T
2Likes
LinkBack URL
About LinkBacks
