Let's have a thread where we discuss our favorite vintage Pickup.
Let's face it, everyone starts winding to make their favorite vintage pickup.
So Here, Let's concentrate on the classics.
My favorite Bridge Humbucker is a 9-9.4k Pickup wound medium tight.
What is yours, You can get as detailed as you want?
Terry
Very nice
"Pushback" wire is ,Wire with a foreskin.
Naa............... Ward ,you should of poped the flame a little more .....lol .... love those toppers
My favourite wood is maple ,My wife's favourite is wood is morning (I still have not figured that one out ......)
Thanks for the comps. I sprayed a couple of coats of clear on the coils and that's all the potting they got, .688 mags, the tops are 4mm thick and the coil is stock height. The formvar comes up well under the lacquer don't you think![]()
Ward, You got anymore Pics, of those fancy guitars and Pickups?
T
Keep Rockin!
Terry
Rightio, here's another master piece brfff. P-90s rule and having the one in the middle gives so much more variety. Turn up the treble n presence and P-90s are great. Pos's 2 n 4 are great as well. Actually because I've gone maple mad I'm planning to ditch the white covers and put a 1/4'' maple top on these. The look of 3 x P-90s is a bit bulky but if you love single coil tone P-90s are a must in the arsenal. I actually know a few blokes who've never heard em
The bridge is an AM STD but those offset saddles have been replaced with the vintage steel ones, you need to drill new holes in the back of the top plate but once you do that the bridge is better IMO with the bent steel saddles and besides, try replacing the offsets with anything other than graphite if you're a lefty.
http://![]()
You realize I'm a Lefty too.
You could probably send me one of your culls!
T
Keep Rockin!
Terry
Here's a couple Tele Pickups I made for a local player.
He wanted to try a neck P/U without the cover.
A good thing, I was out of them.
I wound both with 42 AWG.
T
Attachment 18682Attachment 18683
Keep Rockin!
Terry
Always good to leave the cover off them Tele neck pickups I reckon.
Here's a Tele triple set of woodys ready for winding. The neck n mid are strat spec.
I made this thick steel bridge for it, incomplete in this pic, it's in the polishing process at the moment, no plating, just polished to look like chrome, I've done this many times and never have rust issues , I tested it out on the guitar and the added tone is very noticeable esp in the bottoms, like the bottom is wider and bigger but also the top strings really spit out at you. Steel rules for tone, forget brass, that's rubbish. This is for my thinline. Fun job making the pickup hole, job satisfaction to a tee. Not a Big Teee, just a tee
I posted these in another thread, thought some may be interested. Half humbucker singles that can easily be made into P-90s with the addition of another bar mag.
I wonder what a tele neck pickup would look like if I subbed the top piece with a piece of pick guard, or a piece of Formica.
I'm not equipped to do Ward's wood working?
T
Keep Rockin!
Terry
The easiest way to do that is to just glue the piece on top of the existing flatwork, drilling the holes accurately for the poles to go through is the hardest part. If you replace the top flatwork altogether you'll need something that will not crack when you drive the rods into it, that's one reason why my woody tops need to be as thick, so they don't break and also they look better IMO but for what you're talking about it's just simple to leave the forbon there and glue on a top piece. HTH.
Keep Rockin!
Terry
Just copy the the top piece of the flatwork with the router or template sander
copy one of these ,there are the bigger top when no cover is used
Mojo Pickup Parts » 2115381 Mojotone Tele Neck Flatwork Wide Top and Bottom Set (for .195'' dia. magnets)
I wouldn't want to be holding such a small piece while trying to rout that. I make all my woody tops by hand, routers are great but don't care if it's your fingers they rout. Of course the top piece from Mojo would make a great template, it doesn't take long at all to hand cut and hand sand something like that. Even though you would have the template, it's still not that easy drilling the holes exactly. Trial n error until you come up with the best way.
I use a small drill press, and drill through another top piece, I use a small C clamp to hold everything.
You have to do lots of turning the drill on and off, and takes some time.
I have also drilled through humbucker slug bobbins.
I made a narrower neck pickup for a import strat by drilling through a 49.2 Humbucker bobbin.
T
Keep Rockin!
Terry
Here's a steel pole tele pup with a tap ,I made a little while ago![]()
What is the sound difference between it and a regular Tele bridge?
T
Keep Rockin!
Terry
I use 2 small opposing ceramic magnets
There might be enough room for 2 firebird magnets but not full size bar magnet
