Results 1 to 4 of 4
Thread: Anyone With Experience with 6L6GB's in Tweed Fenders?
    Supporting Member Zer09's Avatar
    May 2010
    NJ
    78
    I've got a few pairs that do nothing but collect dust and I've always wanted to give them a try just out of curiosity. I was just wondering how far past the specs on the data sheets they can be pushed. I feel safe with plate dissipation but my concern has always been the screens. The datasheets say 270v but true to form Leo went well beyond that. Anyone who can share their experience with them?
    Jul 2011
    Adelaide, South Oz
    261
    Since noone has responded here is my view FWIW.
    6L6GC has Va and Vg2 ratings of 500V and an anode dissipation rating of 30W.
    6L6GB has Va rating of 360V and a Vg2 rating of 270V AND MOST IMPORTANTLY an anode dissipation rating of 19W.
    Tubes are quite tolerant of over voltage and in this case I suspect that the voltage ratings are very conservative. About the time that the 6L6GC was released tube manufacturers changed the way that they listed ratings and so the 'GB will almost certainly tolerate higher voltages. The system changed from a "Design Centre" rating system to an "Absolute Maximum" rating system. So the data an the 'GB is likely to be "Design Centre" whereas the data on the 'GC is likely to be "Absolute Maximum"
    It is that last anode dissipation rating which would concern me (even if it is a "Design Centre" value) - it would certainly require a lower bias point (lower idle current) so I would not recommend just plugging them in to see what happens.
    For some chat on tube rating systems see John Broskie Blog here:
    The Tube CAD Journal,New Mu Follower
    Hope this is of some value to you.
    Cheers,
    Ian
    Oct 2011
    93
    I'm using these in my 5F4 clone:
    http://www.natubes.com/data/images/p.../large_241.gif
    the plate voltage (in idle) is someting like 430V (I know, I have an out-of-spec PT, should be 410V), the screens are the same (I have a choke between them, as in 5F6 bassman)
    of course, in full tilt the B+ sags to something like 380V, so I guess it's a bit easier on the tubes. (and yes, I like playing the amp in full tilt, either using attenuator or rocking flat out)
    I wouldn't worry about the dissipation either, these particular tubes have much bigger plates than, say, real 5881's. I bias them as if they had 23W plate dissipation rating
    I also used these for years, http://natubes.com/data/images/product/large_243.gif
    also no problems whatsoever
    May 2010
    NJ
    78
    Thanks to both of you. I feel much more comfortable trying them now. I'm using 5881's right now with 400v on both plates and screens. It was the screens I was concerned about but it sounds like I should be fine. I'm not expecting any magic from them or anything but I'd hate to see good NOS tubes go to waste.
  1. Capacitor Pans on fenders?
    By wcrankshaw in forum Build Your Amp
    Last Post: 05-27-2010, 02:12 PM
  2. Leo Fenders pickup winder
    By belwar in forum Pickup Makers
    Last Post: 01-11-2010, 09:16 PM
  3. Brown/Blonde Fenders
    By cminor9 in forum Build Your Amp
    Last Post: 11-18-2008, 05:49 PM
  4. Vintage Fenders For Sale
    By womantone in forum Flea Market
    Last Post: 11-05-2008, 12:26 AM
  5. P.I input cap in Fenders
    By chocopower in forum Mods & Tweeks
    Last Post: 06-14-2007, 07:06 AM
