Results 1 to 7 of 7
Thread: Am I magnetizing wrong
    Feb 2012
    18
    Earlier today I wound my first set of pickups (single coils) for a custom guitar that I built. I am thinking that I did a poor job of magnetizing them because they haave EXTREMELY low output. so I wanted to check with you guys for feedback. I have two of the rare earth magnets that I put in a vise and I slowly put each pickup through it two or three times. Stewmac recommends that you use four rare earth magnets (I didnt know this at the time that I ordered) so Im thinking I might need to double up on the magnets and re-magnetize, perhaps I also need to pass the pups through the magnetic field a few more times? Im not really sure so I hope you guys can help me out. By the way, my alnico magnet slugs and my flatwork was all purchased from addiction-fx.com if that means anything. Thanks in advance. -Alex
    Jun 2008
    PDX
    159
    If the two rare earth magnets came together the way they are mounted, would they repel each other or attract? They should attract. That is their polarity should all face the same direction.
    It really doesn't take much to magnetize an alnico using rare earth magnets. When passing them through it is best to not let the alnico touch the rare earth magnets. Try insulating the charging magnets with a very thin piece of cardboard, like you find on the back of a legal pad. Pass the pickup through at a steady rate and try to keep an even path and stay on path until well away from the charging magnets.
    Once charged be sure to keep them away from anything that may take the charge away. Any pics of your setup?
    Roadhouse Pickups
    Feb 2012
    18
    Quote Originally Posted by Magnut View Post
    They attracted to eachother (i tested this to make sure I was setting them correctly in the vise). I also used my polarity tester to verify this. When passig them through, I did have a hard time keeping the pups from touching the magnets so I covered the magnets with painters tape and put the pups through a few more times. Should I have de-magnetized the pups after they touched the magnets? What problems does that cause? Also, how many times should I pass them through the magnetic field (like I said above, I put them through two or three times). I'll post some picks of my home-made winder shortly and the guitar that I made with the pickups (gotta dig out my camera!). Thanks -Alex
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    On a melting ice pan in the North Atlantic
    1,383
    Quote Originally Posted by windycityblues View Post
    If you have the stew mac magnets i would just leave them in the plastic cases they come in & stick them to the vise in the proper orientation
    STEWMAC.COM : Instructions for Pickup Kit for Strat
    I have charged quite a few pickups using these
    "Pushback" wire is ,Wire with a foreskin.
    Feb 2012
    18
    Quote Originally Posted by copperheadroads View Post
    How many of the stewmac magnets do you use?
    Jun 2009
    1,383
    When I was using them,I only had 2
  7. #7
    Feb 2012
    18
    Thanks for all the help, just one last question. How many times did you pass the pickups through the magnetic field? -Alex
  1. Magnetizing Ceramic 8
    By copperheadroads in forum Pickup Makers
    Last Post: 03-19-2011, 06:07 AM
  2. Magnetizing
    By Hella1hella in forum Beginner's Corner
    Last Post: 03-16-2011, 02:45 PM
  3. Which grade of Neo magnets is best for Magnetizing
    By tonedeciple in forum Pickup Makers
    Last Post: 03-08-2010, 01:55 AM
  4. Neo magnet procedures for magnetizing
    By Woodenspoke in forum Pickup Makers
    Last Post: 03-31-2009, 07:07 PM
  5. Ok, I've made a magnetizing jig... now what?
    By LtKojak in forum Pickup Makers
    Last Post: 01-04-2009, 04:46 AM
