Results 1 to 3 of 3
Thread: Adding a headphone Jack Socket
    Jun 2012
    1
    Hi,
    I know it is probably a basic question for most of you but I wonder if you could help me out with a simple amp mod. I would like to add a headphone socket to an amp (probably a Fender FM212).
    Could it be as simple as putting a switched stereo jack socket in line by disconnecting wires to the speakers, connecting them to a switched jack and then feeding back from the switch to the speakers OR would I need any electronics in line to modify the signall to make it suitable for headphones?
    Any info gratefully received
    Steve
    Dec 2011
    Pretoria, South Africa
    164
    Try 120 Ohm resistors, one in each line of tip and ring. Wire the socket such that it cuts out the speaker signal.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    Or just tie Tip and Ring together and use one resistor, the amp is not stereo anyway.
    Fender.com has many amp schematics on there, you might look at how they wired the headphones jack on some other models. Seems to me that other amps in the FM/Frontman series had headphones.
  1. Headphone socket
    By Shakey 1047 in forum Mods & Tweeks
    Last Post: 08-01-2011, 04:32 PM
  2. Headphone jack for a Marshall VS265
    By booj in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-08-2010, 12:10 AM
  3. MG30dfx headphone jack
    By Conker09 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-08-2009, 05:26 AM
  4. headphone jack?
    By thesesimplewords in forum Theory & Design
    Last Post: 01-20-2007, 07:36 AM
  5. Add a headphone jack
    By rzylman in forum Mods & Tweeks
    Last Post: 08-16-2006, 11:44 PM
