Results 1 to 10 of 10
Thread: anyone else having problems with mws wire
    Senior Member madialex's Avatar
    866
    I bought a 5 lb spool about 6 months ago and it has been the shittiest wire ever. About half the spool was ok but mid way through the wire isnt smooth any more. Kinda wavy looking and now if i wind with my normal tension it breaks everytime. None of the other wire i have from other vendors breaks even if i go to the max tension. I need the tension to get the tone im wanting. Do they take wire back? Im irritated as all hell with it.
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,456
    Quote Originally Posted by madialex View Post
    I Have the exact same problem.
    My roll of Essex red 42 SPN (From MWS) is hanging up and breaking.
    About 1/3 of a six pound spool remains.
    It is hanging right in the middle of the spool.
    No apparent problem, but the damn thing breaks just the same.
    I have a P-Bass Bobbin half wound.
    T
    Keep Rockin!
    Terry
    866
    Does the wire have this wavy look going on, mine does and its like you said, breaking all the time.
    Boston, MA area
    2,115
    Call up the wire manufacturer and ask them what's happening. They will at the very least have some ideas.
    Pickup Maker
    Bloomfield, NJ
    10,203
    Quote Originally Posted by big_teee View Post
    Splice it. I do it from time to time and it works fine. Just use a small pieced of tinned hookup wire and wrap both ends around a few times and solder it. Test it from that point to there start lead. If it's good, tape it up and keep winding! If you don't get a reading head up the splice some more.
    I generally stick with Elektrasola wire, and rarely have these snags, but it seems to every so often on the 10 lb rolls. After a while it stops. I never had that happen with the smaller rolls.
    www.sgd-lutherie.com
    www.myspace.com/sgdlutherie
    www.myspace.com/davidschwab
    Jun 2010
    U.S.A.
    4,456
    I spliced it.
    It broke 3 times pretty quick, then it cleaned up.
    All seems ok now.
    T
    Keep Rockin!
    Terry
  7. #7
    Feb 2007
    316
    Never had a problem with MWS wire, though it can get a bit wavy when the spool is almost empty. I did have an MWS spool with a bit of a nick in the rim once that was causing wire to hang up and break. Sanded it smooth, etc.
  8. #8
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    On a melting ice pan in the North Atlantic
    1,388
    I still using a 10 lb spool that I bought from MWS last fall & no trouble so far
    "Pushback" wire is ,Wire with a foreskin.
  9. #9
    295
    No issues here, and I'm on my second spool in the last month.
  10. #10
    725
    No significant problems here. Have seen the wavy thing once in a very great while and only very briefly. I also had a spool a while back that had a bad snag in the middle and I lost a sizable chunk of wire desnagging it. Other than that, smooth sailing...
  1. Replies: 26
    Last Post: 09-23-2011, 12:05 PM
  2. favorite wire stripper for small guage wire?
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-26-2010, 07:42 AM
  3. Wire half gauges? Anybody try Weico wire?
    By achase4u in forum Pickup Makers
    Last Post: 02-06-2009, 11:52 PM
  4. Connecting Magnet Wire and Lead Wire
    By kevinT in forum Pickup Makers
    Last Post: 04-29-2008, 06:21 AM
  5. Any EU and UK people interested in a Group order from MWS?
    By corduroyew in forum Pickup Makers
    Last Post: 02-12-2008, 07:39 AM
