Results 1 to 4 of 4
Thread: Hafler PRO-5000 schematic
    Feb 2009
    Marietta, GA
    15
    Anyone have schematic for Hafler PRO-5000 stereo amp? I have one with one channel out.
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    It's usually a blown resistor, that ties the driver circuit to ground.
    Poke around with an ohm meter and usually it's find-able.
    This resistor blows to protect the amp if the output is overloaded. Replacing it will many times make the amp work again.
    OR, it "could be" something else blown, but check that above first.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,055
    The Hafler web site has several Pro series amps as well as some other P series amps covered under tech support, library archive. No 5000, but you may find other models close enough.
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    296
    PRO2400 sch, may be close enough to do fault finding with.....
    Attached Files Attached Files
  1. Hafler G150 Schematic
    By yba-1 user in forum Schematic Requests
    Last Post: 08-06-2011, 12:00 AM
  2. Hafler P-1500 Schematic Needed
    By gomez63 in forum Schematic Requests
    Last Post: 05-19-2010, 02:04 AM
  3. Hartke 5000 help ?
    By yeti195 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-24-2008, 07:38 PM
  4. 5000 Turns
    By kevinT in forum Pickup Makers
    Last Post: 11-29-2007, 06:52 PM
  5. Zoom 5000
    By DocGeorge in forum Guitar Effects
    Last Post: 05-13-2007, 09:16 PM
