About 3 or 4 years ago I gave myself a Dremel mini blow-torch(don't know how you call them in English - later edited, found it on Amazon, see below, it's called a blow torch indeed). It lights up just like a regular cigar lighter, by clicking a lever the side, you then use a single hand to lock the lever on, then unclick it to cut the gas supply and turn it off, all with one hand. You fill it up with regular butane gas canisters used for all refillable lighters.
Something like this:
Dremel Versaflame Gas Blow Torch + 7 Accessories : Tooled-Up.com but mine doesn't stand up like that.
I apply a little soldering flux to the chassis so that oxidizing doesn't get in the way, then the blow torch solders any thickness chassis in 2 to 3 seconds it's absurd really. The problem with the blow torch is you can probably only use it for new builds. When the amplifier guts are in, if you blow torch it you'll carbonize wires and components around the target.. Also terminal strips and similar will carbonize if you blow torch them, so I use a 2mm(about 3/32") thick leftover scrap brass sheet as a shield which I put in place in front of other components before blow torching. Carbon is a good conductor, so if you happen to blow torch terminal strips and even so slightly carbonize them, they can't be used for high voltage any more. Take it from me, I've blown things up that way.
For the jobs where the blow torch won't do and you still need power, I own one of these:
http://best-b2b.com/userimg/545/546-...g-iron-677.jpg - They're cheap around here, and do the job quickly as well. They just take a long while to heat up, but once that massive head is hot it can white-solder two trucks together.
For circuit/delicate solders, this is an investment I made and I never looked back:
Amazon.com: Weller WTCPT 60 Watts/120V Temperature Controlled Soldering Station: Home Improvement - These things heat up in 10 seconds, and the temperature is controlled. During a bit larger solder, the thing hums and pulls a boatload of current and keeps the tip hot no matter what. A friend of mine underestimated this little beast because it looks delicate and works on 24 volts, after he used mine he also went out and got one.
Scope: I bought one of these in 2008 or 2009.
Amazon.com: Tektronix TDS1001B 40 MHz, 2 CH Digital Storage Oscilloscope w/Monochrome Display: Industrial & Scientific It's the simpler one from the Tek's digital lineup and it does everything you'll ever need in audio and then some. If you're not going for digital, there are millions of great analog scopes on eBay, remember for audio work you don't need the 2 billionhertz bandwidth models, though class D amps may require some more speed but then again I still can't get class D out of my hot bottles
Just throwing my 2 cents in, hope this helps.
