Results 1 to 31 of 31
Thread: Clipped the .002uf cap on bassman 10 and got major distortion
    Dec 2011
    59
    So I thought I would see if I noticed a difference for the better if I removed the cap going from pin 1 to ground. I actually play bass through my amp.
    It's a ceramic cap valued at .002uf it connects pin 1 to pin 8 which is grounded. Pin 5 has a 1500ohm resistor going to Pin 1.
    I thought it was there just to kill parasitic oscillation on the silver face amps and expected it to be going from Pin 5 to ground.
    When I removed them my amp sounded farty and had some strange overtones and distortion.
    Threw them back in and it's back to normal.
    Do I actually have some oscillation that might be to high a freq to hear or is that the wrong cap to be removing?
    Dec 2011
    59
    Also when I did this I measured the bias voltage across the 1ohm resistor from pin 8 to ground as .31mv on each tube.
    I know thats a little on the cold side.
    With the caps back in place it went up to .32mv on each tube. I still have the bias balance circuit in place and plan on going to a "true" bias adjust soon.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    .32mv or 32mv? 32mv is 0.032 volt. 0.32mv is 0.00032 volt. 500 volts on the tube and 32mv across 1 ohm, meaning 32ma current yields 16 watts dissipation. A little cool, but perfectly reasonable.
    Yes, that cap stops parasitics, and when you removed it you probably let them back in.
    It is a brute force method of killing parasitics though, and there are other ways to tame them less obtrusively. But does the amp sound OK with them?
    Dec 2011
    59
    32mv so yeah a little cold
    I think I made a dumb mistake when I disconnected the cap by not providing a path to ground to the grid resistor when I removed the cap.
    It's just that all other silver face schematics show the cap going from pin 5 to ground. The bassman 10 schematic has it going from the other side of the grid resistor (pin 1) to ground.
    The amp sounds ok but still has a little bit of breakup on the initial attack of a plucked note.
    I'd like it a little tighter.
    Supporting Member
    Apr 2009
    NY, NY
    576
    I don't think you want the grid resister to go to ground, that will kill the signal, no?
    Dec 2011
    59
    Your exactly right pontiacpete.
    I was just looking at the schematic.
    I'm still confused then.
    I realize the silver face amps were more prone to oscillation due to lead dress issues but mine is a 72 and looks pretty good compared to some later examples.
    I think parasitic oscillation of frequencies beyond on hearing range can cause the amp to be running at full tilt and sound distorted when an instrument is played but I'm not sure.
    I really did not expect it to sound so bad when I removed those caps. I swore I broke something when I did it.
    Luckily putting them back got me right back where I started.
  7. #7
    Dec 2011
    59
    My bass has active pickups.
    Perhaps the overall gain is to high and it's blocking distortion.
    Maybe I could eliminate the cathode bypass cap on V2? I replaced it with a 4.7uf instead of 5uf when I recapped the entire amp. I believe this would lower the signal the power tubes will see.
    Or maybe going to a true bias adjustment and upping the bias to 35ma would help some?
    I know I'm just spitballin and asking a lot of questions and making mistakes.
    I'm still learning. I just finished reading Tube amp guitar essentials yesterday. Read it cover to cover in one day.
  8. #8
    Supporting Member
    Apr 2009
    NY, NY
    576
    If makes you feel any better I have on many occasions just removed those caps on SF fenders and never had a problem.
    do you have the original bias cap in there?
  9. #9
    Dec 2011
    59
    Quote Originally Posted by pontiacpete View Post
    Nope. I replaced all electrolytics with either FT or sprague using the closet available values.
    I just played again and it sounds good but I can't help feeling there is a slight amount of looseness/distortion to initial attack still. At least compared to my ampeg BA115.
    I probably do the bias conversion later today since it's too hot to go out and work on the car.
  10. #10
    Dec 2011
    59
    Comparing a Silverface Super Reverb schematic to Bassman 10 points out the difference in placement of the oscillation caps.
    Anyone care to postulate what sort of difference it would make and perhaps explain why it sounds like crap on a Bassman 10 when you remove it?
    http://ampwares.com/schematics/super_reverb_aa270.pdf
    http://www.ampwares.com/schematics/Bassman_10_alt.jpg
    Attached Files Attached Files
  11. #11
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    Quote Originally Posted by sleepingAwake View Post
    Hmmm... 32ma, well, IMHO, that is not really cold. Cold would be like 15ma-20ma.
    This whole thing about hotter idle current and 60% or 70% rule is a NET driven idea based on someone else's subjective idea of good guitar tone.
    If you are playing bass then you should stick with your ears and figure out what the idle current is with respect to the plate voltage of the power tubes.
    I think electric bass sounds best with the power tubes idle at around 50%-55% of plate dissipation rating... but that is me and you are you.
    We don't know what your musical tastes are... you might love ugly-nasty bass distortion but active pickups on bass guitars in most vintage amps like a well used 50 watt Bassman 10.... is a mistake unless you really have the gain set very low... it is way too easy to overdrive one or more of the preamp stages with low frequency energy. YUK!
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  12. #12
    Dec 2011
    59
    Quote Originally Posted by Bruce / Mission Amps View Post
    Yes I typically turn down the volume output on my bass. Its a Cirrus with an 18v active system.
    I noticed today that the Studio channel has a lot more low freq output than the Bass. I was surprised by this as I've always used the Bass channel. It seems as those the entire Studio channel has more gain than the Bass channel.
    I can actually feel air moving when using the Studio channel. Not so with the Bass channel.
    I like a nice clean pop with a lot of overtones and harmonics. I'm not a fan of distorted bass.
  13. #13
    Supporting Member
    Staffordshire UK
    1,813
    'Comparing a Silverface Super Reverb schematic to Bassman 10 points out the difference in placement of the oscillation caps.
    Anyone care to postulate what sort of difference it would make and perhaps explain why it sounds like crap on a Bassman 10 when you remove it?'
    My feeling is that the cap placement on the Bassman 10 is probably better, in that putting the caps on the tube grid terminal creates additional antennae.
    'explain why it sounds like crap on a Bassman 10 when you remove it'
    The most likely reason is that the amp is oscillating at an ultrasonic frequency.
    An oscilloscope is very beneficial to resolve the issues causing this.
    'I can't help feeling there is a slight amount of looseness/distortion to initial attack still'
    Are you using a 2 ohm cab with it?
    The reservoir cap values could be increased, in order to give a more solid attack; at least 2 x 100uF, up to 2 x 220uF should be ok.
    Pete.
  14. #14
    Dec 2011
    59
    Quote Originally Posted by pdf64 View Post
    Pete.
    The head is in the original combo cab. I replaced the stock speakers with 4 8ohm Eminence speakers.
    Measuring the resistance on the the speaker jack I get 11.8 ohms. I believe the working load should drop down closer to 8ohm.
    I swapped out the 15k resistor on the bias balance pot today as the old one had drifted to 16k. Not much but enough to limit the bias to 30ma (I got a different reading yesterday??)
    With a fresh 15k resistor I get a nice 34.5ma
    I just noticed something else. On the Bass channel the "Bass" knob has hardly any effect on the tone. You have to strain to tell the difference between 1 and 10 on the knob.
    Maybe that might explain why the Studio channel has so much lower "boom". Like I said the studio channel actually pushes the air around you. The bass channel not at all.
  15. #15
    Supporting Member
    Staffordshire UK
    1,813
    This schematic http://www.webphix.com/schematic%20h...n_10_schem.pdf indicates that the original speakers were 32 ohms each, wired in parallel to achieve a total of 8 ohms.
    How did you connect your 8 ohm speakers?
  16. #16
    Dec 2011
    59
    Series parallel
  17. #17
    Supporting Member
    Feb 2010
    1,549
    Usually an 8 ohm speaker will measure less than 8 ohms on the meter (around 5 to 6 ohms DC resistance). A series parallel arrangement of four 8 ohm speakers should read the same. I would expect a 12 ohm meter reading from a 16 ohm impedance load. Check for open or miswired speakers.
    "So, for my small experience in the trade I would think that killing customers is, at the very least, bad for business." -Chuck H
    Disclaimer: "Take my advice; don't listen to me"-Neil Young. "I'll lie again and again and I'll keep lying; I promise"-Henry Rollins.
  18. #18
    Dec 2011
    59
    Quote Originally Posted by g-one View Post
    I'm really more concerned with my question from earlier. I'll check my wiring but it may be due to some sort of hybrid of series parallel wiring.
    I'm looking at the spec sheet for the speakers I've have and it lists them as 11.4 ohms. Weird I know.
    Does anyone have any more input on this?
    I read somewhere that the bass channel has a LF cut to keep bass players from blowing out speakers back in the days these amps were produced.
  19. #19
    Dec 2011
    59
    Would raising the value circled give me more low end response? 330pf seems awful small.altered-bassman-10-schem.jpg
  20. #20
    18,021
    I'm not sure that the brightness cap is the place to look for bottom end.
  21. #21
    Dec 2011
    59
    Adding capacitance there with a jumper did give me more lows.
    That's the deep switch on the bass channel.
    Not the high freq bypass cap on the bright switch.
    Is there a better spot on the bass channel to be looking more low freq responses and maybe some high overtones.
    The tone stack doesn't look like a typical bassman and I'm still learning so signal path eludes me.
  22. #22
    Dec 2011
    59
    Well I tried some stuff and got more lows but loss some clean headroom in the process.
    Brightened up the channel as well.
    I noticed the heater voltage is low as well at 5.89V.
    I took out a cap that bypassed the 100k resistor and moved over to the bass pot. Mostly because out of the ones I tried it brought the most lows.
    Take a look and please provide input as to how I could do it better.
  23. #23
    Dec 2011
    59
    I guess I'll respond to my own question.
    I've found putting the .001uf cap back in helped regain headroom. It was probably sending some mid and bass freqs to ground.
    Replacing one of the caps on the bass pot with a .0047uf cap has given the bass pot some actual adjustment and gives the amp more bass.
    There are still some sub-bass freq and mids that I would like to kill as it is causing some muddiness but I'm just not sure how to go about it.
    I believe its all a matter of adjusting the signal V1B sees as I think its getting to hot a signal over some frequencies
    latest-change.jpg.
  24. #24
    Jun 2006
    California, USA
    1,646
    It's good that you are experimenting but I suggest that, to progress, you will do well at this stage to learn more of the theory behind the design and voicing of pre-amps. A good source would be Merlin Blencowe's book "Designing Tube Preamps for Guitar and Bass" and/or the TUT series from London Power. You can also download "Duncan's Tone Stack Calculator" and use it to get a feel for the effect of value changes to the various components in the tone stack. All these will be easy to Google. I think you will enjoy the modification work you are doing a lot more once you have a better understanding of the theory. Regards, Tom
  25. #25
    Dec 2011
    59
    I'll check out the reading suggestion Tom.
    I'm a bit disappointed with gerald webers book. I found it repeated the same info over and over again.
    It could have been half the size it was.
    I did download the tone stack calculator the other day but since the bass channel on the bassman 10 differs it isn't helpful to me at this point.
  26. #26
    Supporting Member
    Staffordshire UK
    1,813
    You may be finding out why that bass channel tone control arrangement isn't popular.
    Consider using the regular arrangement as per the studio channel, but tweak a few values, eg 33nF or 68nF for the mid cap, 150 or 330pF for the treble cap.
  27. #27
    Dec 2011
    59
    Yeah it's completely backwards from a normal fender tone stack.
    I thought about changing it to a AA864 tone stack.
  28. #28
    Jun 2006
    California, USA
    1,646
    ...I'm a bit disappointed with gerald webers book...
    Well...suffice it to say that the Weber content in that book is not a bible of correct information.
    ...I did download the tone stack calculator the other day but since the bass channel on the bassman 10 differs it isn't helpful to me at this point.
    Understood. However the calculator will still show you the general effect of value changes of the tone stack components. Did you use the feature that allows you to change the values?
    I'm not sure what your level of experience is. There are good free downloads available of old books. The advantage of the recommendations I made is that they are specific to musical instrument amplifier applications. Take a look at the sample articles on the Valve Wizard site ( How to design valve guitar amplifiers )and let us know if the technical level is right for you.
    Regards,
    Tom
  29. #29
    18,021
    Weber's book is interesting but not very educational. Too often you get "move this here,and change that there' advice without showing the schematic changes nor explaining why they work. The book is basically a how-to guide to modifying your amp without learning anything. I recommend them as later reading, after you know enough to sort out which parts are baloney.
  30. #30
    Dec 2011
    59
    I looked through the website Tom and I can say that some of theory is above my head at this point but I can get a grasp on certains function of a valve.
    Trouble is I'm a hands on learner. Reading about a subject isn't the best way for me to learn about it.
    But it's what I got for now.
    The Bassman 10 bass channel seems to employ the reverse of your standard Bassman tone stack. It looks like there is a high pass filter on one side of the bass pot and then a cap to filter more highs on the other side???
    Trouble is stock that pot sounded the same no matter what you set it to.
  31. #31
    Dec 2011
    59
    I definitely agree with this statement. Having read it in one day I can say it should say cliff notes on the cover.
  1. Major goof, major problem OT
    By captntasty in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-23-2011, 03:41 PM
  2. farty bass problem, Bassman 10
    By otto pärt in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-25-2009, 06:32 PM
  3. Need a 5/10/20 Cap for Silvertone
    By KingCameron in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-23-2008, 03:56 PM
  4. Fender Bassman 10 Question
    By MicroMack in forum Vintage Amps
    Last Post: 01-28-2008, 09:27 PM
  5. Fender Bassman 10 project
    By Blindog in forum Mods & Tweeks
    Last Post: 10-08-2006, 03:49 PM
