Results 1 to 3 of 3
Thread: Peavey Tube Fex Display garbled / gobbledeegook
    Mar 2012
    Bristol, UK
    32
    Hi,
    I have a Tube Fex that I am looking at. It appears that it might be working apart from the display is garbled. You turn it on and the display is just a mess of characters - generally readable characters but incorrect. The unit has firmware version 1.1 and the battery has been removed and the RAM replace non-volatile RAM. I believe that it has worked and just stopped.
    To me it seem that the unit is working as if I press some of the buttons settings change, relays click and the motorised pot whirrs up and down.
    My question to the forum is has anybody seen this fault and resolved it? I was thinking it could just be the display unit that's gone duff.
    Many thanks for reading and any thoughts very welcome.
    Mike
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,066
    Reinitialize the unit?
    Mar 2012
    Bristol, UK
    32
    Hi Enzo,
    Yes I should have said up front the reinitialization sequence mentioned below makes no improvement. Should also add that the sequence of characters displayed which includes lots of currency, punctuation symbols etc and is the same consistent result every power on. I am thinking that if the display module doesn't cost too much, it might be worth substituting it out.
    From Peavey site: TUBEFEX
    Press and hold the down & right cursor on power up. To check the version of firmware, press and hold to down & left cursor on power up.
  1. 5E3 X-Y display of output
    By loudthud in forum Theory & Design
    Last Post: 02-12-2012, 07:26 AM
  2. Behringer PMX2000 display error
    By Ronald in forum Music Electronics
    Last Post: 04-06-2011, 05:58 PM
  3. Large display counter
    By Musiclogic in forum Tools and Coil Winding Gear
    Last Post: 12-25-2009, 03:35 AM
  4. G-Dec display
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-15-2007, 03:18 AM
  5. Having trouble with display mode setting
    By Tom Phillips in forum Lobby
    Last Post: 09-07-2006, 06:17 AM
