Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By J M Fahey
Thread: Power Cascode!
    Senior Member Austin's Avatar
    Jun 2012
    A van down by the RIVER!
    316
    Power Cascode!
    Here is the schematic of how I modified my little magnavox amp. I have converted to solid state diodes and in the place of the 5y3gt added a 6080 tube. The heaters for the el84s and the 12ax7 run from a wall wart and the original heater output goes for the 6080 tube. The 5600 ohm cathode bias resistor is too big I think (and not bypassed) but it was the closest ballpark value I had.
    Question: Can I still half wave rectify some negative volts of this for bias of the bottom tube?
    Crazy? Ha! Maybe. The point is to be able to drive the el84 class a2 for more power.
    My next project I have planned is going to be even further out in left field.
    Tubeswell, I forgot the grid stopper resistor on the top tube again. I was in a hurry to see if it would work but I figured you would point this out so I beat ya to it.
    Jun 2012
    316
    Easy way to bias this?
    Capacitater Steve Conner's Avatar
    Glasgow, Scotland
    6,784
    Out of interest, where do you think the cathode current of the 6080 is going to go? The centre tap of the HT supply can only source current, not sink it.
    Lifetime Member
    2,792
    Hmmm. I think it can sink current. Look at what you have if you disconnect the (-) lead of the full wave bridge and remove the three lower caps and the 12AX7.
    But other issues with the circuit bother me a lot. I haven't done the mental work to put my finger on it, but the 6080 driving the cathode of the EL84 and in turn being driven by the plate of a 12AX7 bother me.
    Glasgow, Scotland
    6,784
    RG, you are right. I still think the circuit looks crazy, though. Sound clips or it didn't happen!
    Jun 2012
    316
    The bias for the 6080 can be from adjusted by changing the value of the 12ax7 plate resistor which I think is cool. The bias for the el84s could come from a bunch of nine volt batteries strung together off the center rail. I like how simple it is.
  7. #7
    Jun 2012
    316
    It works, I am still trying to get the bias right. Anybody got any suggestions? It has a nice sound, very clear. My power supply is getting a little warm tho.
  8. #8
    Oct 2007
    Buenos Aires, Argentina
    4,481
    Well, primitive tube amplifiers got along with 3 batteries: "A", "B" and "C" .
    Yet the full abecedary extends to "Z", so we can still add a lot of new batteries to our circuits and not get confused.
  9. #9
    Jun 2012
    316
    Quote Originally Posted by J M Fahey View Post
    I had to look up "abecedary" and even now that I know the definition, I'm still not sure what you are trying to say with this comment. However I think batteries are a nice simple way to acomplish bias.
  10. #10
    Oct 2007
    4,481
    Don't worry
    Just forgot that in USA "Alphabet" is more commonly used
    Only meant that more letters should be used to avoid confusion between all those batteries
    PS: and, believe it or not, I have often played with lots of 9V batteries, stacking them up to hundreds of volts.
    Live act customers often replace *all* wireless mic batteries at every important show, simply don't gamble with that, not worth it, and I get all the barely used ones iuf I wish.
    Now if you have to *buy* them ... it's different.
    Austin likes this.
  1. 12dw7 for cascode?
    By Austin in forum Theory & Design
    Last Post: 06-26-2012, 06:16 AM
  2. cascode designs
    By blaise in forum Theory & Design
    Last Post: 10-16-2011, 02:22 PM
  3. tube cascode help
    By HTH in forum Guitar Effects
    Last Post: 09-17-2011, 02:05 AM
  4. cascode designs
    Last Post: 04-26-2011, 07:01 PM
  5. Please explain cascode
    By Groover in forum Theory & Design
    Last Post: 02-19-2010, 09:54 PM
