Results 1 to 4 of 4
Thread: laney VC30 drive channel mod
    Senior Member -Elepro-'s Avatar
    Apr 2009
    429
    hello,
    it works well but drive channel needs very high volume to have a not big overdrive.... how can i have a bit more overdrive with less volume??
    here's the schematic
    http://music-electronics-forum.com/a...2_sch_-et-.pdf
    thanks
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    296
    You have several volume controls & two operating modes.
    Make sure you are in DRIVE mode, not in CLEAN mode
    Does the DRIVE led turn on ? If not you wont be able to get more "drive" and you will need a footswitch. You can make a footswitch with a stereo 1/4" plug & some switches. Short TIP to SLEEVE to switch between clean & overdrive, short RING to SLEEVE to turn off reverb
    If you want more distortion in drive mode, with less volume, turn the DRIVE knob up, and turn the DRIVE VOLUME knob down.
    DRIVE controls how much distortion / overdrive you get, and DRIVE VOLUME controls the overall volume.
    CLEAN controls how mush clean volume you get.
    Apr 2009
    429
    Quote Originally Posted by mozwell View Post
    .....If you want more distortion in drive mode, with less volume, turn the DRIVE knob up, and turn the DRIVE VOLUME knob down.....
    yes mozwell.... i understood how knobs work....
    but in this amp, if you turn up the drive knob to max with the drive volume down you have not much distortion.... this because drive stage has not enough gain
    ...i thought to increase the bypass cap of V2a or V2b....
    Sep 2009
    Australia
    296
    It wasnt very clear from your first post exactly what your problem was, so just thought to check the easy things first.
    So, not enough drive.
    1. is your guitar turned up high
    2. are you using the HI or LO input, try the other one & see what happens
    3. turn treble, bass & mid to maximum, do you get enough drive now.
    4. is V2 a 12AX7, does ahcnging this tube help
    5. carefully (with power off & power supply discharged) remove R13, this will give you more signal into V2b
    if you still dont get what you want, maybe try an external overdrive pedal
  1. Laney vc30 -112 sound level problem
    By bunzonoise in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-20-2011, 04:49 PM
  2. Laney VC30 run away bias
    By technicalxpectations in forum Guitar Amps
    Last Post: 06-23-2010, 05:36 AM
  3. laney vc30 wooshing noise
    By snowyguy in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-17-2008, 11:26 AM
  4. Laney VC30 Low volume problem
    By Smily in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-21-2008, 05:59 PM
  5. Sick Laney VC30 112
    By LochNessMonster in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2008, 12:47 PM
