Is it possible that the tank has been replaced, or is it definitly original to the amp? When the drive circuit is designed as this one is, with the input coil in the feedback loop of the driving opamp, I usually see an input coil that reads anywhere between 60-200 ohms. Your 6 ohm reading seems too low to me.
When you touch the two leads of your meter together what reading do you get?
LinkBack URL
About LinkBacks
