Funny I was just thinking about this
I have a bunch of mini humbucker screws from Mojotone that don't fit the baseplates from Mojotone
so all my mini baseplates from mojo use a standard 3-48 humbucker screw
All the ones I've found take larger screws. Anybody know where to get some that take the same mount screws as full size humbuckers?
"Pushback" wire is ,Wire with a foreskin.
I just bought some mini humbucker baseplates from Mojo about a month and a half ago and they have the same threads for the pickup height mounting screw as the Allparts ones that I was using before. It is a 3mm x0.5mm thread. Allparts didn't have the mounting screws so I have been using some 30mm long stainless ones from BoltDepot. They don't look too bad, but I see that Mojo has the nickel 3mm ones now, which might look a little better.
www.sonnywalton.com
How many guitars do you need? Just one more.
There may be a misunderstanding here. I'm not talking about the 6 pole screws but the 2 mount screws.
I was talking about the 2 mounting screws in my post also. Evidently at one time the Mojo parts that copperheadroads got took the standard humbucker mount screws 3-48 UNC, but the ones I got a couple of months ago are like yours with the larger M3-0.5 metric thread, which is the same as the Allparts baseplates have too.
www.sonnywalton.com
My misunderstanding then. Where can these plates with the 3-48 mount holes be found?
Ok here's the deal ,Mojotone actually carries 2 different mini baseplates
the vintage long leg (which is the style I have) uses the standard 3-48 humbucker mounting screw .In the link ,look at the parts list below plate
Mojotone Nickel Silver Long Leg Mini Humbucker Frame 50mm (1.97'')
The other mini baseplate is a short leg style that uses m3 screws
Mojotone Nickel Silver Short Leg Mini Humbucker Frame 50mm (1.97'')
That should do it -- thanks Copperhead. You from down South with a name like that?
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
I was thinking of the species of snake, not fissionable materials.
