Hi all,
I'm in the process of finishing a Two-Stroke amp as detailed in Dave Hunter's Guitar Amp Handbook. However, I'm substituting a Doberman 20 watt SE OT in place of the Hammond 125 ESE that Hunter recommends. The format of the Doberman wiring schematic (
Doberman 20 Watt Single Ended Output Transformer) differs some from the format of the Hammond (
http://www.hammondmfg.com/125SEsch.gif) and I'm hoping someone can do a quick check of my work.
Hunter has the Two-Stroke set up with a switch that selects between the white and yellow wires of the Hammond.
He recommends:
White wire:
2-6V6 @ 8 ohms
1-6L6 (EL34) @ 8 ohms
Yellow wire:
1-6V6 @ 8 ohms
2-6V6 @ 4 ohms
1-6L6 (EL34) @ 4 ohms
From this (
http://www.hammondmfg.com/125SEsch.gif), I gather 2x 6V6 and 1x 6L6 need to see 2500 ohms, while 1x 6V6 should see 5,000 ohms.
Looking at the Doberman schematic (
Doberman 20 Watt Single Ended Output Transformer), it looks like I want to hook up the primary using the brown and brown/yellow wires. Then, the green wire on the Doberman OT will be the equivalent of the white wire on the Hammond (8 ohm secondary @ 2500 ohm primary), and the yellow wire on the Doberman OT will be the equivalent of the yellow wire on the Hammond (4 ohm secondary @ 2500 ohm primary, 8 ohm secondary @ 5000 ohm primary).
Hopefully I'm stating that in a way that makes sense. Basically I just want to know if those wire combinations will get me the closest to the 125ESE.
