Swap the power tubes to see if you have a bad tube or the problem is with something inside the amp connected to that socket.
AC or DC voltages? The DC voltage on pin 5 of a (good) 6L6 in this amp should be 0V. It should be zero volts iven with the tube removed. If it's not, replace the 0.05uF cap(s). That's probably what is pulling down the voltages on the PI pins 2 and 5 and making the 6L6s hot.
LinkBack URL
About LinkBacks
