Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By TDK
Thread: Transistor series switch help
    TDK
    TDK is offline
    Jul 2012
    7
    Hello fellow tinkerers. I'm a guitarist working on an overdrive circuit that will require transistor switching to shunt the signal to ground at various places. I've found a lot of good info online but haven't been able to see the whole picture yet. I need to accomplish the switching with the fewest possible components, as my circuit board is running out of real estate, and with the lowest possible current draw. A lot of the info I've seen about BJT switches suggests that typical current draw is 100 ma, which is far too much current, considering that a lot of effects pedal power supplies are only rated for twice that. I've gotten to the point where my brain is full for the evening and I'm hoping someone can just gift wrap a solution for me. Basically, what I have available is about 8.5v after power supply filtering and one pole of a TPDT stomp switch to alternate power to two pairs of transistors, one pair shunting a gain and volume control to ground as the other pair breaks a shunt to ground for another gain and volume control. I'm not opposed to using SOT transistors if that's what it takes to keep the current draw down. Any takers?
    Oct 2007
    Buenos Aires, Argentina
    4,486
    Audio switching to ground with Bipolars does not take that much current.
    Maybe they talked about using "100mA" capable transistors, meaning small (TO92 or SOT) ones.
    FYI, I switch my distortion circuits ON by grounding clipping diodes+tone/volume pots as needed with a humble TO92 BC546 NPN transistor, with its base connected to +15V through 2 x 10K resistors in series, whose centerpoint gets grounded or not.
    Base (switching) current is: 15000mV/20000 ohms= 0.75 mA.
    Resize resistors depending on your available PSU voltage.
    TDK
    TDK is offline
    Jul 2012
    7
    So you're connecting a positive voltage to the base? I knew it had to be easier than the examples I was finding. All the ones I saw were connecting power to the emitter of a PNP, and it was really only good for energizing relays. So, since I have a ton of 2N5088's, how do I calculate the resistor values for that transistor and 8.5v? Also, I'm assuming your power on/off is affecting conduction from the emitter to the collector, so that the collector is connected to ground and the circuit fragment you want grounded is connected to the emitter. Is that correct?
    Oct 2007
    4,486
    Almost. 2N5088 are fine.
    Emitter to ground, collector to whatever you want to ground, base to +8.5V through a 10K to 22K resistor turns it on .
    Remember you can not have DC, only audio signal, or it will pop horribly.
    If needed, add a series DC blocking cap (1uF to 10uF) and a high value resistor (100K to 1 M) from it to ground to discharge any small voltage which can leak through.
    TDK
    TDK is offline
    Jul 2012
    7
    Yes. Sorry, I got my emitter and collector mixed up. I'm used to working with op amps and jfets. SO the blocking cap is in series with the audio signal being grounded. Where's the high value resistor going? Is it parallel to the capacitor?
    What you described in your first post sounds a little different. It sounded like you were grounding the center of a voltage divider at the base rather than switching power on/off to get collector-emitter conduction. Is there an advantage to that?
    Oct 2007
    4,486
    1) the high value resistor is in parallel with emitter/collector, so even when OFF there is a path to ground for any DC buildup.
    2) I described what I use, as an example.
    In my case the transistor gets switched ON-OFF thanks to a footswitch which grounds a contact.
    You mentioned using some kind of switch which supplies +8.5V to the transistor, practically the opposit arrangement.
    Both are valid, choose one.
    If you want, post a rough schematic of what you are trying to do.
  7. #7
    TDK
    TDK is offline
    Jul 2012
    7
  8. #8
    TDK
    TDK is offline
    Jul 2012
    7
    Hopefully the image shows up ok. As you can see, it's just two sets of tone and volume controls with a switch providing power to one pair or the other. Does this look like I'm on the right track?
  9. #9
    TDK
    TDK is offline
    Jul 2012
    7
    I meant volume and gain, not tone.
  10. #10
    Oct 2007
    4,486
    Yes, that's basically it.
    You will ground either both pots on the left or both on the right.
    Use 10K to 22K resistors in series with each base and I suggest you add from each base to ground a .1 to 1uF cap, to damp any switching click.
  11. #11
    TDK
    TDK is offline
    Jul 2012
    7
    Juan, thank you so much for all of your help. Great information!
    -Tim
    J M Fahey likes this.
  12. #12
    Jul 2012
    1
    Most welcome.
  13. #13
    Oct 2007
    4,486
    ^^^^^^^^^^^ Hey !!! , now *I*'m being cloned?
    You will *need* at least to grow the same beer belly , the same greying beard , semi balding head and other distinguishing features to be at least minimally close
  1. Transistor as a switch
    By lowell in forum Guitar Effects
    Last Post: 12-12-2011, 06:58 AM
  2. series / parallel transformer switch wiring
    By GCA in forum Theory & Design
    Last Post: 02-23-2011, 02:12 AM
  3. Marshall MG series Reverb switch MOD
    By spartadrive_in in forum Mods & Tweeks
    Last Post: 09-01-2009, 05:37 AM
  4. Stratocaster Series Parallel switch mod
    By telemoxy in forum Guitar Tech
    Last Post: 11-12-2008, 04:19 PM
  5. dual triode - single, parallel, series switch
    By camerasteve in forum Mods & Tweeks
    Last Post: 10-11-2008, 03:17 PM
Tags for this Thread
