Results 1 to 8 of 8
Thread: Head pad felt matierial for Reel to reel
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    812
    Interesting that the last thread was about a reel to reel, too.
    Anyway, does anyone know of a source for 'real' felt that can be used for head pressure pads? In this case it could be between 3/16" and 1/8" thick. I've found all kinds of synthetic materials that are too abrasive or might catch on a splice at the typical sewing-hobby type joints.
    A million years ago we used to be able to get a square of this stuff from hobby shops & just cut up your own head pads or even purchase them pre-cut with adhesive backing for this specific purpose, but alas...not much call for that these days.
    I see online where the head pads for cassettes are available with adhesive backing, but of course that's for 1/8" tape & wouldn't work here.
    Any ideas would be greatly appreciated...glen
    g1
    g1 is offline
    Feb 2010
    9,858
    Moleskin? Just a thought. It has adhesive backing and is readily available at drugstores. Not sure if the material is perfect for the application but worth checking out.
    Edit: The kind for blisters
    Certified Dotard
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,399
    Piano felts?
    Got any old reel table clutch felts?
    Go to a fabric store and ask them?
    Are we talking like Echoplex pads? And would one of those work for you?
    Sep 2006
    Englewood, CO
    812
    Thanx for the ideas.
    Yeah, the fabric stores & hobby stores only have the synthetic stuff which is too abrasive or just too thin. I actually have the felt spacers for the Wurlitzer key height adjustments...hadn't thought of that. The Moleskin might work, too.
    the issue might be the felt washers might not be wide enough...but that opens some other sources. Enzo, what felts for the ecoplexes are you referring too & do you know of a source...thanx, glen
    30,399
    I wasn't thinking of the individual key shim felts really, I was thinking the strips of thick felt that run the length of keybeds to act as a downstop cushion. But any port in a storm. I used to have to replace glued in felts under some keybeds that the keys eventually cut through. I want to think PC88s, but I might be confused.
    Well hell, I am stupid. COntact a piano repair guy, or piano store, ANy place that does maintenance/rebuild/service to pianos.
    File:Maestro Echoplex EP-2.jpg - Wikipedia, the free encyclopedia
    From the wiki article, look at the photo. From the left end of the tape cart, coming out from under, see the phosphor-bronze springy strip angling out to the upper left, bent around the lid post, and with a felt pad at its end to keep the tape tight against the lower side of the roller. New spring strips with felt came with new tape carts. I don't know who might sell them nowdays. But at least that is what I was thinking of.
    googling "piano felt" first thing up was this:
    Piano Action Cloth & Felt Products
    second thing:
    Piano felt, cloth and leather action parts for all makes of pianos. Technician's tools.
    Wool felt, not synthetic.
    How about google wool felt: ooh, too many to mention
    Don't know, but google "felt pads" and see various responses.
    Sep 2006
    Englewood, CO
    812
    Hey Enzo,
    thanx for the suggestion of the Wurlitzer & acoustic pianos as a possible source for the felt. I realized that I still had some key felt bumper strips in my Roland stuff. The strip of bumper felt was just over 1/4" wide & just the right thickness a well as with adhesive backing...couldn't have been a better fit.
    g
  7. #7
    Jun 2012
    36
    edited
  8. #8
    Jul 2012
    10
    Enzo is the one with bright ideas. Thank Enzo replying Mars Amp Repair.
  1. Teac x3r reel to reel troubleshooting help
    By jasonguitar in forum Music Electronics
    Last Post: 06-12-2011, 03:27 PM
  2. 3M Wollensak Reel To Reel Recoder W / Tube Amp
    By Hurricane in forum Guitar Amps
    Last Post: 06-16-2010, 03:48 AM
  3. 6aq5 powered reel to reel tape recorder conversion
    By Johnrcurry in forum Conversion Projects
    Last Post: 03-27-2009, 10:51 PM
  4. Roberts reel to reel conversion, some quick Q's
    By truth_hz in forum Conversion Projects
    Last Post: 11-04-2008, 06:30 AM
  5. Suggestions on converting a RCA tube reel-to-reel
    By DinoSS100 in forum Conversion Projects
    Last Post: 01-24-2008, 07:30 PM
