Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By soundguruman
Thread: Peavey XR 684f 'no power to mixer'
    Sep 2009
    Cheshire UK
    48
    Hi again guy's
    Xr684f has no power to the front board, the rear power board is working ok so far with ipod pluged into L+R amp inputs sound is good!!
    I checked the ribon conector at the mixer board end and its showing +0.68v at pin 8
    Should pin 8 be +15v??
    I followed it back to the power board and transistor Q215 is showing 0v at pin 1 and 0.68 at pin 3
    I need to test further but i have no schmatics for the power board! if there is one about could someone point me in that direction as i only seem to find front board schems.
    Thankyou hope your all well
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    I think you might have a dead regulator?
    Looks like unregulated 10 volts on pin 8, on what I have, but it may not be the same. Check on both sides of R267...
    Attached Files Attached Files
    J M Fahey likes this.
    Sep 2009
    Cheshire UK
    48
    Thankyou Soundguruman
    Ok just a recap on Q215!!... There is +29.9v at pin 1 'not 0v like i said before', i missread what i had checked
    So there is only .7v at pin 3 on Q215 and iv checked R267 and it also showing .7v on both sides.
    I'm going to change Q215 first and take it from there, i need to order them in as nobody local seems to have them on the shelf
    Jul 2011
    California
    1,682
    Quote Originally Posted by MARSHALL BUSTER View Post
    Well actually, thank PV service department. They have always supported us with parts and schematics.
    Q 215 is a 7815 voltage regulator, easily available at almost at any electronics store, in stock almost everywhere,
    7815T: MAJOR BRANDS: ICs & Semiconductors
    they do blow now and then.
    But why did it blow? Is there something drawing too much current on the +15 rail?
    try LM7815 or NTE968
  1. PEAVEY XR 400 Mixer AMP (200H schematic) Transistor ID Help
    By justusjamie in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-11-2011, 02:08 AM
  2. Peavey XR-560 powered Mixer blowing fuse
    By gcb34 in forum Music Electronics
    Last Post: 03-27-2011, 10:55 PM
  3. Peavey XR 1600D powered mixer no output
    By DM40744 in forum Other Amps
    Last Post: 03-05-2011, 07:28 PM
  4. Behringer PMH2000 is Peavey XR-684F
    By zero cool in forum Music Electronics
    Last Post: 03-26-2010, 06:46 AM
  5. Peavey XR 684F - Amp section
    By zero cool in forum Schematic Requests
    Last Post: 02-11-2010, 02:10 PM
