Results 1 to 2 of 2
Thread: Blacktop P90 Jag project
    Feb 2012
    PNW
    41
    Hi,
    I have a (B)P90 Blacktop Jag that I want to modify. I really like the guitar and like the rude P90 sound I would like a bit of a brighter option so here is my idea. Please let me know if you see any issues with my idea.
    First the P90's.
    I think I am going to replace the stock tone/vol pots with two jazz bass style concentric pots and wire it up in an independent tone/volume setup like a modified LP.
    I am considering routing a center Jag single coil in an SSS fashion and replace the three way with a 5 way "Megaswitch".
    I will then route in the rhythm controls and use those for tone and volume on the center pickup and use the switch as a cut out.
    So the Megaswitch would be set up as follows
    Bridge – Bridge & Neck – Center - Neck & Center - Neck
    Because I would have independent volumes the rhythm slider would work as a mute when the center pickup is turned off and the 5 way is in the middle. If I watch my commings and goings positions 2 and 4 should be hum canceling too.
    I could use the standard switches but they are less “stage friendly”
    Thank you in advance for you input, I can't find another setup like this so I'm not sure if I am nuts or not.
    Feb 2012
    PNW
    41
    As an update I did need to mess with the wind of the center pickup a bit and I used a six way rotary in place of the toggle. I have made two of these so far and I have had customers make me sell them to them before I could take pictures or do any recordings.
    When I locate another one of these guitars for cheap I'll make another.
    I was going to draw it out in cad it out but if you find the google docs images for a Jag, print out the pickup pocket you are good to go. I didn't bother with the upper control cavity.
  1. P90
    By SpareRibs in forum Beginner/ Hobbyist
    Last Post: 07-01-2011, 07:03 PM
  2. Fender Jag-Stang Pickups
    By magnetic sound in forum Pickup Makers
    Last Post: 02-13-2011, 07:40 PM
  3. My First P90
    By tonedeciple in forum Pickup Makers
    Last Post: 08-10-2009, 02:18 AM
  4. Lollar P90 vs dimarzio virtual p90?
    By daz in forum Guitar Tech
    Last Post: 12-10-2008, 10:44 PM
  5. Apology to: GTR TECH and JAG.
    By Danglin' Fury in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-22-2008, 01:03 AM
