Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By madialex
Thread: Same turns, different DC resistance
    Supporting Member
    Jul 2012
    Brighton, England
    28
    I just wound the two coils of a precision pup, 10,000 turns each, and one has DC resistance of 5.9K, the other 6.6K.
    what gives? and should I care?
    Dec 2008
    Oz
    398
    Quote Originally Posted by Kesh View Post
    With your meter check for continuity between the outer mags and the start wire. If you get a reading you have a short to the mag. This will account for the drc oddity. Does it matter? to some it does, to others not. If you have no reading then you must have stretched the wire more on the 6.6k coil.
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    On a melting ice pan in the North Atlantic
    1,387
    Did you solder the leads then take readings ?
    "Pushback" wire is ,Wire with a foreskin.
    Supporting Member
    Jul 2012
    Brighton, England
    28
    There's no short, didn't expect there to be one as I taped the mags and sprayed lacquer.
    The first coil has been soldered. It was maybe 5.95 before soldering, 5.93 after, the second is still on the winder.
    I'm guessing I stretched it, or maybe my improvised turn counter messed up. Can't decide whether to take some wire off or just leave it.
    It's my first wind, and I'm pretty pleased with not breaking the wire and not getting a dead pick up at the end, so meh.
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,455
    If it is a split P bass P/U, then figure where you want the hottest two strings and put the hot one there.
    If I make another P set, I'm going to try making the P/U for the E & A a little taller than the D & G P/U, but not much taller.
    T
    Keep Rockin!
    Terry
    Dec 2008
    Oz
    398
    Yeah, could be a bodgy counter???
  7. #7
    Supporting Member
    Jul 2012
    Brighton, England
    28
    Quote Originally Posted by big_teee View Post
    T
    I figure as hot = lower frequency response, I'd put the overwound one on EA. I could always lower it a tad if there's a volume mismatch.
  8. #8
    May 2012
    USA
    366
    That would be a hell of a lot of stretching.
    Make sure you take your measurements after both pickups have been sitting at the same temperature for at least a few hours.
  9. #9
    May 2012
    USA
    366
    Quote Originally Posted by Ward View Post
    I have a "favorite" single coil in the neck position of one of my Strats that I wound ages ago. I know it's shorted from the finish end to one of the outer poles (it reads just a hair under the full DCR reading of the coil) and it sounds absolutely amazing.
    Go figure.
  10. #10
    PDX
    2,399
    What counter sensor arrangement are you using? Were you winding faster on the second coil? Does the counter have a debounced setting for slower speeds?
    I'd see if the current pair give you enough hum canceling but if these were mine I wouldn't hesitate to start over. I can't tell you off hand what a P coil at 10000 turns is supposed to measure but i don't think either measurement is out of the ballpark for 42AWG.
  11. #11
    Jun 2010
    U.S.A.
    4,455
    Quote Originally Posted by David King View Post
    According to the StewMac Instructions a 10000 turn coil should measure around 5.25k, and the pair should measure 10.5k dcr.
    So you should be well in excess of 10000 turns if you used 42 AWG wire.
    You should get more mids over the 10k Turns.
    T
    Keep Rockin!
    Terry
  12. #12
    Senior Member Jim Shine's Avatar
    Jan 2009
    172
    Do you think the tension was consistent between the two?
  13. #13
    Mar 2012
    Moscow, Russia
    32
    Do you can measure inductance on both coils? If they are realy consist same amount of winds, inductance are same on both coils.
  14. #14
    Supporting Member
    Jul 2012
    Brighton, England
    28
    Well I scrapped the hot one, and wound another that came out just under 5.8.
    Put them in my bass, and literally no noise at all. Amazing, especially when compared to the jazz pup at the bridge as a non-cancelling reference.
    Magnet, reed switch, wired to calculator. Both at 400 rpm.
    T
    I think that may be just a ball park. Magnet wire specs I've looked at say about +/-10% ohms. And temperature changes; I measured them when they were hot from potting and they'd jumped a lot.
    Quote Originally Posted by Jim Shine View Post
    I was using felt between fingers, so probably not.
    Quote Originally Posted by Ilya F. View Post
    Do you can measure inductance on both coils? If they are really consist same amount of winds, inductance are same on both coils.
    I would be very interested in knowing how to do this. Seems I need a sine wave generator as well as my multimeter.
    This is very much a made in my kitchen kind of project. By good fortune the pick up sounds great.
  15. #15
    Mar 2012
    Moscow, Russia
    32
    I measure inductance with multimeter with this function. This is the simplest way to do it.
    Different values ​​could happen because counter was missed turns, 400 rpm are too high speed for a calc. Some calculators do not have such a performance.
  16. #16
    Dec 2008
    Oz
    398
    Yeah, calculator, reed switch
  17. #17
    Boston, MA area
    2,115
    Be careful. Most multimeters cannot measure the inductance of a low Q (high resistance compared to the inductive reactance) inductor such as a guitar pickup, and give wildly wrong answers.
  18. #18
    Mar 2012
    Moscow, Russia
    32
    I'm know it Inductance at different frequencies (100Hz, 1000 Hz, 10,000 Hz) are different values.
    But if the coils are identical, they show approximately the same value inductance at any measured frequency.
  19. #19
    Senior Member madialex's Avatar
    866
    Hey heres an idea, Were the TPL the exact same on both? If one had wider scatter its gonna read higher. Pickups 101.....
    David Schwab likes this.
  20. #20
    May 2012
    USA
    366
    Quote Originally Posted by madialex View Post
    Any difference in scatter would change the TPL for any single traverse.
  21. #21
    PDX
    2,399
    I think the "problem" is almost certainly related to the counter missing some turns.
    Glad the rewind got you consistent results and a great sounding pickup Kesh.
  1. Replies: 12
    Last Post: 12-29-2010, 05:08 PM
  2. DC Resistance after potting
    By Chadheckler1 in forum Pickup Makers
    Last Post: 08-08-2009, 10:57 PM
  3. DC Resistance
    By eggman6 in forum Pickup Makers
    Last Post: 02-22-2009, 02:27 AM
  4. lower dc resistance
    By slagg in forum Pickup Makers
    Last Post: 12-29-2007, 08:12 PM
  5. Checking DC Resistance.
    By Aka Nameless in forum Pickup Makers
    Last Post: 07-06-2007, 11:20 PM
