Results 1 to 7 of 7
Thread: 3/8" bushing/longer thread solid round shaft pots?
    Jul 2008
    Southampton, NJ
    51
    i'm in need of them...specifically a dual 1m audio and a 1k lin. i like Bourns but cant' find the values i need.
    Old Timer soundguruman's Avatar
    Jul 2011
    California
    1,682
    Look around antique electronics supply, tubesandmore.com
    you have to special order from a bourns dealer, they have audio grade pots.
    may not be stocked, but you can order it.
    May 2007
    pacific north west
    5,884
    Alpha does make the dual pot in both linear and audio (approx 15% taper). They DO have a shallow thread, BUT, it's a 3/8" hole. It's a fairly shallow thread. You may need to modify mounting to accomodate. I don't know of a deeper thread 3/8" hole pot in a dual 1M of any taper. Good luck.
    Is this for a specific repair? Is this for a personal design?
    "I should have been born sooner. Of course, if I had been, I might be dead now." trem
    Jul 2008
    Southampton, NJ
    51
    i have an amp that a friend built for me. its an Orange clone/copy so he made an Orange style face plate out of more than heavy enough steel which is the same gauge of steel that he used for the chassis.
    i guess i'll start at Bourns site with an email to them...
    Jul 2011
    California
    1,682
    Quote Originally Posted by Foxfire View Post
    You should look through the bourns catalogs and formulate the part number:
    http://www.bourns.com/data/global/pd..._pro_audio.pdf
    http://www.bourns.com/data/global/pdfs/PDA24.pdf
    For example, PDA242 SRT-02- 105A2 is
    dual concentric 1 meg audio taper, with a plain shaft...
    You MUST research your part numbers, before you make a special order.
    Unfortunately, a lot of the people who sell off the shelf controls, won't be bothered to explain the physical measurements.
    OR if they do, the measurements are WRONG. and so, I can see the frustration.
    I have the same difficulty all the time.
    If I was going to do this I would contact Precision Electronics Canada, and ask them to make the controls.
    Just because, I like their construction and I like the super even taper of the control...
    ( Audio taper can mean quite a range of options, and many pots are different)
    AND I like the stainless steel construction.
    Jul 2008
    Southampton, NJ
    51
    i did start looking in to Bourns numbering system but i'll take a look a PEC before i get to involved with Bourns. thanks for the tips...
  7. #7
    Jul 2011
    California
    1,682
    Precision Electronics Corporation: Potentiometers
    Check out MIL style 2RV7
    CALL the factory and talk to the applications engineer directly.
    If I was building from scratch, I would use PEC without hesitation.
    I have never found a finer control for audio.
    NOTE: PEC has stainless steel shaft. You MUST use knobs with a steel set screw. Brass set screw will not work.
    Fender knobs have steel set screws. Cheap knobs do not.
  1. The latest "whaddya think of this winder" thread
    By Sweetfinger in forum Tools and Coil Winding Gear
    Last Post: 01-27-2011, 02:07 PM
  2. Behringer Parts Surplus Blowout..."Pots By The Pound"!!!
    By jrfrond in forum Music Electronics
    Last Post: 07-29-2010, 04:30 PM
  3. Yet another "Weber Kits" thread
    By axpro in forum Build Your Amp
    Last Post: 03-22-2010, 04:16 AM
  4. "Post Your Pedalboard" Thread
    By BTBAM in forum Guitar Effects
    Last Post: 03-17-2009, 12:13 PM
  5. Source for d shaft pots ?
    By danielzink in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-01-2008, 10:45 PM
