Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Guitarman53
Thread: Marshall JCM2000 DSL 401 channel switching issue resolved.
    Jul 2012
    2
    Lightbulb Marshall JCM2000 DSL 401 channel switching issue resolved.
    How I fixed my MARSHALL JCM2000 DSL combo manual channel switching issue.
    PROBLEM: Green LED and therefore "Clean Channel" not operating from front panel switches. (Although OK via foot-switch)
    DIAGNOSES: All channels switched via foot-switch so I was doubtful that there was a component issue.
    I zoned in on the foot-switch input jack at the rear of the amp.
    SOLUTION: Looking at the foot-switch socket, there are 3 spring-metal "clamps" that open to allow contact with the foot-switch plug when it's inserted.
    I found that the tip connector (the most innermost "clamp" ) was not springing back hard enough to create an electrical connection when the plug was removed.
    So I inserted a plug all the way in, thus opening the tip "clamp" with the tip of the plug. I got a screwdriver and forced/bent the end of the metal clip downwards around the tip of the inserted plug.
    Upon removal of the foot-switch plug, I immediately heard a "click" and the front green LED turned on. I then tested the 3 LEDs & channels with a guitar via manual and foot-switch operation.
    Fixed!!! Hope this helps someone else.
    pontiacpete likes this.
    Dec 2008
    Wernersville, PA
    5,369
    Nice repair.
    Thanks for sharing the info.
  1. Jcm2000 Dsl 401 Not changing channels
    By hutsch in forum Guitar Amps
    Last Post: 07-25-2012, 06:28 AM
  2. Marshall DSL 401 help!!!!
    By bru10 in forum Guitar Amps
    Last Post: 10-10-2010, 06:20 PM
  3. Marhsall jcm2000 DSL-401 - footswitch won't switch between od1/od2 (front panel will)
    By thehoj in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-16-2010, 09:48 AM
  4. JCM2000 DSL 401 No Sound
    By Jay D in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-12-2010, 12:47 AM
  5. Help!!! Marshall DSL 401 Issue!!!
    By sscamaro14 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-14-2008, 10:36 PM
