Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Joe Gwinn
Thread: Wiring the microswitch and counter
    Feb 2012
    Hong Kong
    24
    I am building a pickup winder from a sewing machine motor. The dimmer works well to control the speed, but I am having trouble working out how to connect the counter and microswitch.
    I bought a mechanical counter with two wires and microswitches (I make mistakes so I need extra) with the standard COM, NC and NO lugs. The microswitch voltage is "under AC/DC 125/250V"
    I can't seem to find the proper wiring combination to get the switch and counter to work.
    Any advice is greatly appreciated, and thanks in advance.
    EDIT - I got it working. Please feel free to delete this post (I can't find the means to do so).
    PDX
    2,399
    Just for future reference to anyone searching...
    COM is common, NC is Normally Closed, NO is Normally Open.
    Most microswitches will start giving erratic counts at higher speeds as the terminals will bounce causing false counts. You may want an eccentric cam to move the switch lever just enough to actuate it rather than a sharp lobe cam the bangs into it and than drops it every time around. The electromechanical counter you are using is probably ideal for this application as it should be quite resistant to false counts compared to an electronic totalizer that is much more sensitive to fast pulses (and over-counts).
    Boston, MA area
    2,115
    Verify that the counts are correct. It's easy to be fooled.
    You may need a simple resistor-capacitor debounce circuit between microswitch and counter.
    Stratz likes this.
  1. New winder needing help with counter wiring
    By stbailey in forum Tools and Coil Winding Gear
    Last Post: 09-01-2012, 06:31 AM
  2. New winder needing help with counter wiring
    By stbailey in forum Beginner/ Hobbyist
    Last Post: 07-18-2012, 08:23 PM
  3. Idiot (me) needs help wiring sensor to Red Lion Cub3 Counter
    By Bryan Jeppson in forum Tools and Coil Winding Gear
    Last Post: 04-20-2011, 01:41 PM
  4. Which counter
    By Bill Scheltema in forum Tools and Coil Winding Gear
    Last Post: 04-28-2010, 01:24 AM
  5. Another sensor to counter wiring post
    By jpike in forum Tools and Coil Winding Gear
    Last Post: 04-16-2010, 06:08 PM
