Results 1 to 5 of 5
Thread: Marshall jcm900 oscillating
    Supporting Member
    Apr 2009
    NY, NY
    576
    This amp came in with the volume going in and out. I found R30 on the high/low switch opened. REplaced and it's working fine except there's also an oscillation that can be heard when inserting half way into the input. IOW, when the tip lifts the ground of the input jack the oscillation can be heard. I replaced C5 because it sounded microphonic when tapped. But not the problem. When tapping on the ICs 1 and 4 the oscillation is affected, it sounds like it vibrates with the tapping.
    It seems like IC 1 is most affected by the tapping. But I'm not sure.
    How do I determine what's causing the oscillation?
    And if it is one of the ICs is a 4558 a good sub for the 5201?
    Strike the last question: I found jrfond answered way back, NJN2120 or 4560 work as subs. But which one if any to stop the oscillation?
    Attached Files Attached Files
    Supporting Member
    Feb 2010
    1,549
    What kind of gain and volume settings do you have when the squeal is caused by the input jack? The ground switch of the jack connects to point F of the V1 grid circuit. So if the gain and volumes are set high, I would expect some squeal when plugging halfway into the input.
    As far as microphonic IC's go, if they exist they are extremely rare. I would expect something else near they IC may be the problem.
    The 5201 is a switching op amp, looks like the NJM2120 is also, the 4560 is not.
    "So, for my small experience in the trade I would think that killing customers is, at the very least, bad for business." -Chuck H
    Disclaimer: "Take my advice; don't listen to me"-Neil Young. "I'll lie again and again and I'll keep lying; I promise"-Henry Rollins.
    Supporting Member
    Apr 2009
    NY, NY
    576
    Thanks g-one. I neglected mention that it only happens when the boost channel is engaged and the gain is set to '8' and the vol to '5' half way, the oscillation tone occurs.
    Jun 2007
    2,710
    Is this really a problem? If you plug a cord into the front of the amp that is not plugged into a guitar the amp will make a lot of noise and will probably oscillate if the gain is high enough.
    What normal operation of the amp will require the plug to be half inserted into the input?
    Supporting Member
    Apr 2009
    NY, NY
    576
    I guess there's no problem then, I was just over worrying when I kept hear this somewhat loud tone as I plugged into the amp.
    Thanks for the help
  1. Marshall JCM900 Help
    By marcumh in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2012, 02:49 AM
  2. Oscillating Marshall 5275 SolidState
    By Agent_Smith in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-15-2012, 06:03 PM
  3. Marshall JCM900 4100
    By titan7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-13-2008, 02:48 AM
  4. marshall slx power amp oscillating
    By swt in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-23-2007, 04:31 PM
  5. Marshall clone oscillating via presence pot
    By Doug in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-28-2007, 01:12 AM
