You know Gibson ,What ever they had at the time ,should be the same as the later T TOPS screws
I might be wrong
Would anybody happen to have any idea what alloy the Gibson Dirty Fingers fillister screws are made from?
The Dirty Fingers is a high DCR triple ceramic magnet humbucker
Thanks
Rob.
I might be wrong
"Pushback" wire is ,Wire with a foreskin.
The right answer is: WHATEVER they had in the parts bin that day.
Do you really think Gibson EVER ordered screws to spec for a certain p'up? NOT A FRIGGING CHANCE IN HELL!
I have a 1978 DF, the screws are the same as a broken T-Top from 1981.
What alloy were they made of? I guess nobody will ever known for certain, specially Gibson itself.
BTW, you worry too much 'bout minutiae. In the end, you'll end up making it with the parts there are available to you, isn't it?
Being a ceramic, I'd go with 1018 screws and I'd try some 1215 as well.
Last, but not least, actual DFs are nothing like the old ones, but I don't care as I hate'em with a passion. Both of them.![]()
Pepe aka Lt. Kojak
Milano, Italy
Problem is that I have a customer that has his 2 favorite DF pickups. Some time ago he replaced the factory fillister screws on one of them with hex head screws and no longer has the original screws, now he wants me to replace the hex screws with fillister screws from my stock.
I tried 1010, 1018, 12L14, 1215 and none have the bite that the originals have. I swapped the original screws from the other DF pickup he has and it's a perfect match to both our ears. I am trying to order 1022's from Addiction-FX but they're not responding.
Whatever screws the DF came with have a very hard biting sound to them and I've not been able to match it with what I have.
I've tried both new screws and and old screws from various Gibson pickups I have and I still cant match it.
I'm hoping they're 1022 as it's the only other common screw I don't know if I've tried yet.
Of course if the new 1022 is Chinese and the originals were not then there's no way I'm ever going to match it.
Standard 3/4" Terry.
Take one row of screws of the other pickup, fill the empty spaces with the ones you've got, set up the highs a notch and call it a day...?![]()
Pepe aka Lt. Kojak
Milano, Italy
Keep Rockin!
Terry
1022 was never used by Gibson, Dirty Fingers would be the same as TTop pole screws probably. For about $40 you can them destructively analyzed, problem is that no one makes the right alloy pole screws for TTops that I know of, you'd have to make them yourself or buy 5,000 of them, the usual minimum. I had some made about 8 years ago, send me your address and I'll send you handfull to try out, I almost never use them here....
http://www.SDpickups.com
Stephens Design Pickups
They are pretty good sounding pickups, but an oddball design, I guess they were trying to be Gibson's version of Super Distortion pickups. I have a set and there are 3 ceramic magnets in them, the coils are shielded with copper tape. One of them is actually wound on TTop bobbins, 12 screws in each pickup. I think Gibson still makes them though they probably dont sound like the originals I bet. The TTop bobbin one has long leg baseplate and the other has short legs, both have stamped patent numbers on the bottom.
